0 registered (), 174 Guests and 0 Spiders online.
#100427 - 17/01/03 07:24 PM Odd squeak in 4wd.
Tagawichin Offline
Loc: Central PA
Last week I took some vacation to go out for Pennsylvania's late muzzleloader season. I did not get a chance to shoot a deer but I did get to play in the snow with my Xterra. I have driven qiute a few differnet vehiles in the snow and ice (mostly humvves and Hemmit tankers in the army), but I have to say the Xterra is by far the best. I do have studded winter tread on, but they can only to so much on snow and ice. I do not concider traveling forestry roads "offroading" but they can be nasy with fresh snow over top of packed snow that is more like a hockey rink.
Even with the bad roads, my "stomp the gas/mash the break" test was very impresive. It was very close to the responce I get in 2wd with the stock grabbers.
The one thing that I am concerned about is the squeek that I noticed while using 4wd. Its a knid of cool manly tank tread squeak, but not somthing I realy think should be coming from my drive line. It only seemed to happen when I was on the gas and not coasting. It is a dry metal on metal squeak that happens on a regular interval. It did remind me of the noise that most tracked vehicles make. It did not seem to be too affected by the engine rpms, I mostly cruised a little above idle unless I was climbing a hill. It did seem to come and got at times.
Is this noise common with the Xterra?
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
Herbert Spencer, 1820-1903
#100428 - 23/01/03 03:37 AM Re: Odd squeak in 4wd.
Takeabreath Offline
Loc: Indianapolis,IN
My first thought would be to check for foreign objects (rocks, twigs, branch,or even a lost stud, etc) in your wheels. Take your wheels off and have a look. If you've been in muck or water, you might need to repack your bearings.
edit to add this link, also:
http://www.wtopnews.com/index.php?sid=23920&nid=34
"Dogs Love Trucks."
#100429 - 24/01/03 01:03 PM Re: Odd squeak in 4wd.
Tagawichin Offline
Loc: Central PA
Thanks for the info. I just had the abs recall work done on monday with the scheduled maintaince. We got some snow last night and I listend for the squeak on the way home and did not hear it. If it reoccurs again I guess I have to break out the old grease gun and take a closer look under the truck.
#100430 - 09/04/03 09:15 AM Re: Odd squeak in 4wd.
XCETRA Offline
Loc: Utah
Wheel bearing seal could be dry.
www.passion-movie.com
