193
#102217 - 22/03/06 06:58 PM
Will 35" Tires fit 2005 with 3" BL
Hi all!
First let me say that this is a great site. So much helpful information. However, I searched the forums and could not really find 2005 Xterra specific info regarding my question, mostly topics on 1st gen X's.
Now for the question...
I have a 2005 SE 2wd. Pretty much gonna be a mall crawler. I just purchased a 3" BL but have not yet installed it. I was just wondering if I could fit 35" tires when the BL is installed. I realize that my MPG will drop, but since its my weekend car, it doesnt really matter to me. Will I have any major problems? Thanks in advance for any help you all can provide.
#102218 - 22/03/06 07:27 PM
Re: Will 35" Tires fit 2005 with 3" BL
Welcome! 35's on a 2wd mall crawler...sigh. Well, 32's are a stock size....and if you are not off roading, you probably won't be stuffing the tires into the wells on compression...and, a BL is the best protection against compression rub as it is...so the 35's will stick out about 1.5" more than 32's would...pretty sure that's doable as you are lifting 3". Lifting doesn't do as much for inside the well hits at full lock...so the extra 1.5" swinging in an arc may come close/hit the well liner. As not many people have tried 35's on a next gen X...you're best bet is to head over to the tire shop, and see if they'll let you test mount a set....do some circles in the P. Lot, and see what's what. The turn stops are adjustable, so if its not too bad of a hit, you can adjust it so it won't hit, etc. People have also used a blowdryer to reshape the well liners to allow fatter tires as well. Also, the section width will play a role as well, as in a 12.5" SW will be more likely to rub than a 10.5" SW, etc....as you don't off road, wheel spacers can also get you some extra clearance in that regard... Take pics, post them, and add yourself to the pioneers of the next generation. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#102219 - 23/03/06 07:23 AM
Thanks for the info TJ. I'm going to try and have the lift, tires and wheels on within a month. I'll be sure to post pics. Thanks again!
#102220 - 23/03/06 07:35 AM
I doubt they will fit. Measure your rear wheel wells.
#102221 - 23/03/06 08:42 AM
I think the rear wells are ~36" across. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#102222 - 23/03/06 05:10 PM
You're right TJ. I just measured it and it appears to be just around 36". Thanks again guys.
#102223 - 24/03/06 09:07 AM
Yeah, 1/2" on each side of the tire is not much clearence. ![smile smile](/forums/images/graemlins/default/smile.gif)
#102224 - 24/03/06 10:41 AM
Hey, even if it rubs, we get data. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#102225 - 26/03/06 09:47 PM
not a chance i have 33 inch bfg mud terrains and they barely fit, and i have most of the plastic cut/ molded.
#102226 - 27/03/06 09:38 AM
4x2offroad,
is that with a body lift that you had to do the cutting and molding, or without a body lift?
thanks
#102227 - 27/03/06 01:18 PM
o sorry about that forgot you said body lift.I am without a body lift, but even with it it'd be close i hope if fits though, if i wouldnt known it did i wouldnt done it.
#102228 - 29/03/06 01:43 PM
Originally posted by TJ: 35's on a 2wd mall crawler...sigh. I wouldn't mind 35's on a 2wd Protruck Dimensions
Wheel Base: 122 Inches (122") Front Track Width: 80 Inches (80") (outside to outside of wheels) Rear Track Width: 77 Inches (77") (outside to outside of wheels) Front Wheel Travel: 21 Inches (21") Front Wheel Droop: 5 Inches (5") Front Wheel Bump: 15 Inches (15") Rear Wheel Travel: 24+ Inches (24"+) Rear Wheel Droop: 6 Inches (6") Rear Wheel Bump: 18 Inches (18") Ride Height: 18 Inches (18") Vehicle Weight: 3900 Pounds + or - Fuel Capacity: 40 Gallons
Protruck Specifications
Chassis: Tig Welded Chromoly Space Frame Construction Front Suspension Type: Double A-Arm (Coil-Over) Rear Suspension Type: 4 Link With Straight Axle (Coil-Over) Body Style: Ford F-150 Body Construction: Fiberglass Engine: Small Block (360 Ci Max 9.5:1 Compression Ratio) Rear Axle: Ford 9 Or 10 Inch Transmission: Mogi Turbo 400 Tire Size: 35x12.50r15 Yokohama Geolander Mt+ Wheel Size: American Racing Outlaw Ii 15x7
#102229 - 29/03/06 02:21 PM
So, Chris, what mall is that taken at? ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#102230 - 30/03/06 08:19 AM
Originally posted by TJ: So, Chris, what mall is that taken at?
Mexico? You see the Suburban in the back ground right? A Better question is, what kind of "mall"? ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#102231 - 31/03/06 05:59 AM
Oh, I thought it might be that Baja Mall. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#102233 - 31/03/06 08:38 AM
Yeah, the P. Lot's FULL of 2wd's on 35's. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#102234 - 03/04/06 03:05 PM
back on the original ![smile smile](/forums/images/graemlins/default/smile.gif) here's a pic of a navara with 35s for what it's worth ![](http://www.4x4parts.com/ubbthreads/attachments/460925-PICT0058.JPG) 17x10 alloy wheels 35x12.5R17 Toyo's
#102235 - 03/04/06 06:28 PM
That does look sweet. I mean, except for the mall crawler running board things...and no remaining uptravel. But I like it. Go figure. :rolleyes:
#102236 - 22/04/06 11:19 AM
But I like it.
Go figure.
:rolleyes: ok, I agree with TJ...
#102237 - 24/04/06 09:48 AM
What kind of wheels are those?
