0 registered (), 174 Guests and 0 Spiders online.
#10980 - 10/01/08 05:06 PM stock jack...
with a 3" SL and 33" tires will the stock jack be useful at all anymore?? or will i need a larger hydraulic jack or high lift if i get a flat on the street?? i have never used it but there is a decent amount of storage space in there if i dont carry it around lol...
#10981 - 10/01/08 05:37 PM Re: stock jack...
for the back you can still use the stock jack if you place it under the axle. For the front it will still work you just need to get creative with placement. You can always carry around a few short cuts of 2x4 on the roof basket.
#10982 - 15/01/08 06:23 PM Re: stock jack...
I have a 3" SL and 33" tires. I tried to use my stock jack this weekend, tires never left the ground. Was also weary of the additional weight from mod craziness. A small floor jack only worked with the use of wood blocks. Try a decent sized floor jack with a higher height range or get a hi-lift to carry around, works for me. You should have one anyways, 48" will fit across the back cargo area.
#10983 - 15/01/08 06:40 PM Re: stock jack...
You guys need to stick it under the reaf axle and under the the control arms up front.
I have 35s and still use the stock jack.
#10984 - 15/01/08 06:59 PM Re: stock jack...
Big Daddy Chia Offline
Loc: Austin, TX
And a solid front axle goober.
Scott "Chia" Holland
"God created man. Sam Colt made them equal"
