0 registered (), 310 Guests and 0 Spiders online.
#155 - 06/09/07 11:45 PM Any advice for droopy sun visors?
Any tricks for tightening my visors?
#156 - 07/09/07 11:26 AM Re: Any advice for droopy sun visors?
GrayHam Offline
Visor-agra?
Shit. That was bad. frown
I apologize. It's Friday . . .
#157 - 09/09/07 04:50 PM Re: Any advice for droopy sun visors?
If I thought I could sew neatly enough, loop velcro on the headliner (if there's something for it to attach to) and hook velcro on the visor would probably work. Color match at the fabric store.
#158 - 10/09/07 08:48 PM Re: Any advice for droopy sun visors?
Did you try tightening the mounting bolts? confused
#159 - 17/09/07 02:20 PM Re: Any advice for droopy sun visors?
Duct tape around thingmajig and push back into bracket [drink]
#160 - 17/09/07 03:46 PM Re: Any advice for droopy sun visors?
The mounting brackets are fine, it's the aforementioned 'thingmajig' that's the problem.
The duct tape thing might work, but I don't want to make things worse.
#161 - 18/09/07 08:05 AM Re: Any advice for droopy sun visors?
Stonecoldchavez Offline
Loc: New Jersey
I have the same problem with my driver's side visor drooping. I tried cuttng a small piece of velcro and attaching it to the rubber molding of my sunroof and the inside of the visor. It did not work too well. It was fine for holding up the visor, but when I went to pull it down, the velcro adhesive was not strong enough to stick to the the visor fabric and would pull off.
If you do not have a sunroof, I do not know if the roof fabric will provide a strong enough bond for both surfaces.
Stone
#162 - 01/10/07 03:49 PM Re: Any advice for droopy sun visors?
I might try removing it and squeezing some Silicone glue (Clear) let it dry and reinstall this will cause the joint to be a bit tighter so they do not turn on their own
#683080 - 02/12/18 09:27 PM Re: Any advice for droopy sun visors? [Re: Anonymous]
sierra77 Offline
I replaced my sun rotted visor with one I got from the junk yard and the replacement is droopy!
So I will try to wedge a zip tie to increase friction and if that doesnt work I may try a squirt of hot melt glue in the rod tunnel.
But I am still looking for solutions.
