Yesterday at 10:44 AM
0 registered (), 159 Guests and 0 Spiders online.
#181255 - 21/01/01 07:26 PM O/D Off
lqqker Offline
Loc: Maryville, IL, US
The manual doesn't seem very clear on when you should have the Overdrive on or off. Should I leave it on all the time?
Thanks,
#181256 - 21/01/01 09:32 PM Re: O/D Off
Impavette Offline
Loc: Long Island, New York
I leave it on, unless I am towing my boat. I don't think there is a black and white rule on when to use it. You will get much better mileage if you leave it o/d on. If you are towng you may want to shut it off so you don't strain the engine.
Chris
'00 Xterra SE 4X4 Auto(Silver Ice)
Chris
#181257 - 25/01/01 06:08 PM Re: O/D Off
Ag_xterra Offline
Loc: San Antonio, TX
I use my overdrive like a third gear. when i'm cruising and want to slow down i first turn off the overdrive to allow the engine to slow some then use the brakes. just habit i guess. leave it on all the time. it doesnt hurt. it will give you better gas mileage with it on.
#181258 - 16/02/01 06:58 PM Re: O/D Off
BigTom Offline
Loc: Brownsburg, Indiana
I have noticed the O/D doesn't kick in untill the X is up to operating temperature. I leave mine on all the time unless I am going up & down hills where it wants to shift back and forth.
'01 Silver Ice XE 4X4 3 pack V6 AT
BT
"Why do today what you can put off until tomorrow?"
#181259 - 18/02/01 09:47 AM Re: O/D Off
rob in Austin Offline
Loc: the womb of an angry jackal
I usually turn mine off when going up to the ski mountain or something.
"Facts are the enemy of truth."
#181260 - 25/02/01 05:03 PM Re: O/D Off
BigTom Offline
The way I see it, using it to slow down instead of the brakes could be costly. I would rather pay to change the brakes than to rebuild the transmission. Just something to think about.
#181261 - 01/03/01 11:07 AM Re: O/D Off
TomC Offline
Loc: Plymouth, Ma, U.S.A.
Hey just a quick reply................. I was told by my sales person(Definitely knowledgeable) to leave it on all the time. This is my second vehicle with O/D and was told to ALWAYS leave it on. Not sure why just passing along the information.
2001 Solar Yellow SE 4x4 Auto
#181262 - 24/03/01 08:13 PM Re: O/D Off
yellowX Offline
Loc: Austin, TX
Thanks,
lqqker,
After driving automatics and stick shifts for a while, I discovered that the Overdrive, to me, is like a 4th or 5th higher gear. I would turn off the OD if my vehicle is going up a steep, long incline on a moutain or hill. It's like downshifting so that you can pick up some torque to go up the slope. Once I either reach the top of the hill or have enough momentum going, the OD goes active "ON" again.
yellowX
2001 SE 2WD
Solar Yellow
#181263 - 05/04/01 11:03 AM Re: O/D Off
XSAL Offline
Loc: 94043 -> 19355
What O/D does is basically control the transmission gears. When O/D is ON, you drive with all 4 gears or speeds (if equipped with 4-speed tranny). When O/D is OFF, you drive with only first 3 gears. (...tranny does not use the 4th gear, so you can get the constant power to tow or whatever) That's what I heard from a mechanic, anyway.
Moderator:  johngraves2
