0 registered (), 112 Guests and 0 Spiders online.
#22036 - 01/06/08 04:36 PM 2" Body Lift Problem, Need HELP!!
I am at the point where I'm lifting the truck up and sliding in the 2" pucks. On the second body mount from the front, there appears to be some sort of metal sleeve between the frame and body that in theory, with the puck installed, would make that lifting point higher than the rest.
I'm thinking about drilling the center hole of the puck to compensate for this metal sleeve.
Any thoughts, suggestions, experience this before?
#22037 - 01/06/08 08:08 PM Re: 2" Body Lift Problem, Need HELP!!
Sounds like your old mount separated. You should not have to drill any of the Pucks out.
#22038 - 02/06/08 05:13 AM Re: 2" Body Lift Problem, Need HELP!!
Sounds like a call to their tech support to describe the problem in detail.
Pics? That might help the more experienced here solve the problem for you.
#22039 - 02/06/08 07:50 AM Re: 2" Body Lift Problem, Need HELP!!
It turns out the problem was only on the passenger side. It looks like it was a factory mistake and unfortunatlly I do not have a digital camera to take some pics. I ended up drilling out the puck for that mount and everything worked out fine.
Strange
