Originally posted by Chiefbaddog:
Originally posted by Jasonazx:
[b]32x11.50X15 or you could maybe get away with 33x10.50X15 on the stock wheels. The 32's fit real well on the stock wheels. Just minor trimming on the plastic that no one will notice. You will want that bigger tire after the pml. I really can't see much of difference in fuel economy especially from the 31's to the 32's. The fuel economy difference between those two tire sizes is pretty minuit, so you might as well go with the bigger tire.
May not be that big from 31 - 32 but again, this still needs to be a daily driver which is already only getting around 14.5mpg city so I want to optimize the happy medium. BTW - have any idea what mpg the white rhino's getting? and... saw some old pics of your beast with the T/A KO's - what did you think - why the switch to M/T's?[/b]I see what you're saying, and I was the same way when I first started out. I rocked the 31X10.50 for awhile, and then the 32X11.50 both being the bfg all terrain. I would say that after running both you might as well go up to 32X11.50. Definately recommend the all-terrain though. I just wanted a tire with a slightly softer compound hence the reason I switched to the mud-terrains. The all-terrains seemed to be a little harder, and the rocks were eaten em up. I also wanted to go with a taller thinner tire (33X10.50), as they seem to do well with the terrain we have out here. I am also very interested in traveling to baja and mexico. So, I wanted a tire that could perform in a variety of different terrain. The all-terrains are not the best choice for mud. The mud-terrain has proven excellent. A lot quieter than I thought they would be-not much louder if at all than my all-terrains. The tire wear amazingly enough seems to be about the same. I have done round trips to colorado in them already as well as many other adventures including Mexico and they are holding up very well. All in all you can't go wrong with either in my opinion. Just get them at discount tire with the warranty plan. I have used that bad boy so many times.
