0 registered (), 291 Guests and 0 Spiders online.
#281536 - 14/07/02 07:02 PM 17's on 4x2 XE
xtetra Offline
Loc: Dallas, TX
After searching through the forums for the past two days, I still have a couple of questions about swapping the stock steel 15x7's with the new 17x8 rims available on the 2002 X. I'm purchasing a 2002 4x2 XE this week and would like to buy the stock 17x8's from www.capitalwheels.com. I'm researching tires available and of course cannot find much as far as 265/65R17. After using some tire calculators, I think 275/60R17 and 17x8 Xterra rims will fit, hopefully without looking ricey.
Has anyone tried this combination on a 4x2? If so, do you have pictures?
Why do 4cyl XE's have small tire height? (see below) There must be a reason Nissan does not use 265/75R15.
I'm worried that 275 is too wide? But it's only a centimeter, so it shouldn't rub anything, right? 275/60R17's can be found for $80/tire, so they're worth a look.
Here are the stock specs...
Tire Size / Rim ./ Overall Height (Diameter)
265/70R15 / 15x7 / 29.61 in - stock 15"
265/70R16 / 16x7 / 30.61 in - stock 16"
265/65R17 / 17x8 / 30.56 in - stock 17"
So, would this size be a good replacement for the 15's?
275/60R17 / 17x8 / 29.99 in - (similar height to stock 15's)
Has anyone tried this yet? I'm not looking to rice out the X, just want a clean look for street driving. I will use the 15's for off-roading (with different tires, of course). Any help is appreciated. Feel free to flame if necessary...
Selling MR2 Turbo for a 4cyl Xterra. Does Nissan make a mid-engine SUV?
www.geocities.com/stuffaboutdavid
#281537 - 16/07/02 03:16 AM Re: 17's on 4x2 XE
Devin Offline
Loc: Arvada, CO
i just bought a 2002 w/17" wheels. if you want BFG AT T/A's, the biggest they make for 17" wheels is 265 70R17. you have to remove the front mud flaps but they fit with about 1/2" of clearance when the wheel is cut. i think the overall diameter on these is like 31.7" or something. i don't know about any other tires as BFG's are the one and only for me.
good luck!
