#287954 - 04/12/04 06:56 PM Factory alarm and Remote Starter not being friends
OK I installed the remote starter and that portion of the unit is working well, the problem is that I cannot use the factory alarm. If I set the alarm and use the aftermarket remote to open the doors the alarm goes off. Also if I lock the doors with the aftermarket remote the alarm will not set. There is a remote disarm and arm wire from the unit, but I am not sure what wire to connect them to, I have a FSM, and cannot find the wire to do the trick... Any help is greatly appreciated..
#287955 - 04/12/04 08:19 PM Re: Factory alarm and Remote Starter not being friends
Do you want to have both, or do you just want the aftermarket?
#287956 - 05/12/04 04:47 AM Re: Factory alarm and Remote Starter not being friends
In a perfect world I would like ot have both, meaning being able to lock and set the alarm with the aftermarket remote but I would settle for just disarming the alarm.
#287957 - 05/12/04 02:31 PM Re: Factory alarm and Remote Starter not being friends
what brand of aftermarket alarm are you using? I think the first thing I would try is to program your aftermarket alarm remote to the Nissan alarm.
Its worth a shot. Here are directions, make sure you lock the doors with the switch once you are inside after step 1:
http://www.xterraparts.com/html/instruct/remote.html
#287958 - 05/12/04 02:34 PM Re: Factory alarm and Remote Starter not being friends
I got it working, I had to use the signal from the key cylinder so that now with the aftermarket remote I can unlock and lock the doors which at the same time is arming and disarming the factory alarm. So now I dont have to use two remotes... Thanks..
#287959 - 05/12/04 06:24 PM Re: Factory alarm and Remote Starter not being friends
cool, glad you got it worked out. smile
