0 registered (), 45 Guests and 0 Spiders online.
#295674 - 08/07/04 04:06 PM AMP power wire
I need to run my 4AWG from my Yellow Top to the cargo area, where my amps are mounted. Where is the easiest place to go through the fire wall?
#295675 - 08/07/04 04:56 PM Re: AMP power wire
I do believe it's on the passenger side somewhere, then you can pull of the clamps for the carpet and run it up the passenger side of the x.
#295676 - 08/07/04 09:07 PM Re: AMP power wire
I already pulled the passenger seat out, and pulled back the carpet. I couldn't see any gromet through the firewall or any open place to drill a new hole. The entire underbody of the X is covered by skid plates. The ONLY passenger side idea I found was by removing the air recirculator, and HIGH up behind the dash. I'll take a pic and post it here later this week.
I figured somebody here would have already ran a fat power wire and have a few "pointers". I'm thinking I might just run it through the frame, and find a place to come up under the cargo area.
Still looking for ideas though.....
Jason
#295677 - 08/07/04 09:21 PM Re: AMP power wire
MaloCS Offline
I just did this a few weeks ago. You can't visually see the grommet from the cabin. Open the engine hood and look for a group of wires entering the cabin through a rubber grommet on the passenger side.
I took a wire coat hanger and attached my amp wire to it. I then ran the amp wire into the cabin. Once the coat hanger penetrates the grommet you will be able to see it from inside the cabin.
Good luck. smile
#295678 - 08/07/04 09:33 PM Re: AMP power wire
AWESOME
What gauge wire did you run?
Can you please sent me the pics?
skydive814@insightbb.com
#295679 - 08/07/04 10:58 PM Re: AMP power wire
Mine was done with 4 gauge wire that has a sleeve on it.
#295680 - 08/07/04 11:43 PM Re: AMP power wire
MaloCS Offline
I don't remember the exact guage I used but I was able to find an awesome amp wiring kit from Wal Mart for $20 or so. Don't laugh, the wire supplied in the kit was quality and all the connectors were supplied as well. Give em a looksie.
Actually, now that I think about it, I used 8 guage wire which is plenty big enough for my 100watt amp.
#295681 - 09/07/04 09:03 AM Re: AMP power wire
Horns180 - you have any pics?
MalcoCS - can I see your pics? I already have everything I need to wire the amps. I just need to get through the firewall
#295682 - 09/07/04 09:32 AM Re: AMP power wire
I ran 0 Awg through the OEM grommet. Looking into the engine compartment, left side and down a little bit you will notice wires running into the passenger compartment, as previously stated by someone else.
If you can't figure it out, you could always take it to a reputable shop that specializes in such things to do it for you.
#295683 - 09/07/04 09:34 AM Re: AMP power wire
i ran my 4 gauge through the driver side. with the 4 gauge all you need is a little force to get it started and it will spread the grommit it self. it comes in just to the left of the break. from there i just ran it under to carpet right next to the tranny tunnel. [Smoking]
#295684 - 12/07/04 11:54 PM Re: AMP power wire
OK guys, thanks for all the help. I got my 4awg ran to the cargo area tonight, so that's out of the way. My JL VR600's should be here tomorrow, and my PG 1 farad cap and 8" Stinger crossblow fan are on the way.
Now it's time to start up the "fiber glass enclosure" thread smile
Consider this a CLOSED topic
