So I installed a set of 100 Watt LightForce driving lights connected as follows...
12V switch from the factory fog lamp hot wire at the light connector.
To a 30A relay connected to the battery and out to the lights.
W/ this wiring my installed relay is inline w/ the factory fog relay and everything seems to be working fine since I figure my relay is the one taking the 100w draw from the lights.
My question is, would the factory relay, since it's still in line for the 12v switch, be changing any amperage (or voltage, or whatever) going to the installed relay that could cause any long term damage or reducing any wattage potential I could be sending to the lights?
I'm not a wiring guru, I knew enough to make the lights come on but I'm not sure if this setup is adequate (I know it's not necessarily ideal) for what I have running.
