0 registered (), 227 Guests and 0 Spiders online.
#308961 - 08/04/05 07:30 PM Head unit install - quick ?
I've been reading the various posts ... very helpful and I want to thank everyone for their input and insightful comments.
I just bought a 2005 S (w/o RF system) and am in the process of connecting the harness to my CDA-7875. One quick question for anybody knowledgeable - off of my head unit is a black ground wire ... off the two-piece harness are 2 separate black grounds - one labeled "amplifier ground" and one labeled "chassis ground." May be a stupid question, but I want to make sure I do this right to prevent any unneccessary noise - Do I connect the head unit ground to one of these two grounds on the harness, or do I run the head unit ground directly to the chassis? What did you guys do? Any input will be greatly appreciated ... thanks.
#308962 - 08/04/05 07:48 PM Re: Head unit install - quick ?
While the harnesses (factory and the wiring kit) had all those extra ground wires labeled for various things, my new head unit only had one ground - so none of that other stuff really mattered.
I grounded mine to the chassis - there's a bolt on each side in back of the opening where the HU slides in. I used my tester to "prove" the one on the right was a good ground and used that. Sandwiched the ground connecter around the bolt between the two brackets that the bolt holds together.
No noise at all, not even on AM.
#308963 - 08/04/05 08:09 PM Re: Head unit install - quick ?
Thanx X -
Think it's okay to just cut them off then?
#308964 - 08/04/05 09:24 PM Re: Head unit install - quick ?
I wouldn't cut them off - that's kinda final. Never know what ya might be installing in a few years.... might end up needing 'em someday!
I just wrapped the ends in electrical tape.
