0 registered (), 170 Guests and 0 Spiders online.
#40213 - 29/06/07 05:00 PM What is this?? Picture
That plastic tube..looks like a resonator? It's not connected to anything thats all I know..
#40214 - 29/06/07 05:49 PM Re: What is this?? Picture
ripcurl2151 Offline
Loc: NJ
i was wondering the same thing when i replaced my radiator. checked the service manual quickly and couldn't find anything
"If you want the ultimate thrill you have to be willing to pay the ultimate price"
#40215 - 29/06/07 05:59 PM Re: What is this?? Picture
I'm pretty sure it is a resonator. It comes off of the intake and doesn't really go anywhere. When I did my snorkel it came off and never went back on.
#40216 - 30/06/07 07:05 AM Re: What is this?? Picture
I took mine off and plugged the hole in the intake with a bottle cap. It is a resonator as was said above.
#40217 - 30/06/07 07:22 AM Re: What is this?? Picture
Yeah it's there to quiet down the noise of the intake..
#40218 - 01/07/07 11:20 AM Re: What is this?? Picture
It goes down and under into behind the fender. If you peel away your wheel-well liner, you will find a 12" long box. I removed mine, as well as the resonator. Sounds better. I believe it adds 25 hp! :rolleyes:
#40219 - 02/07/07 03:39 PM Re: What is this?? Picture
Resonator, one of three. Or as I like to call them, pieces of plastic that now take up space in my garage.
#40220 - 02/07/07 08:37 PM Re: What is this?? Picture
FSRBIKER Offline
Loc: Oak Ridge, NJ
Would you ever put them back??
FSRBIKER
97 TJ, 2" lift, 32's
EOE...Opening Soon!
#40221 - 03/07/07 06:09 AM Re: What is this?? Picture
I put mine back..it actually does seem to make it smoother and quieter..maybe it's just me though.
#40222 - 03/07/07 07:28 AM Re: What is this?? Picture
Mines been off for a while. If you take it off make sure to seal up the hole to keep the water out.
#40223 - 03/07/07 09:49 AM Re: What is this?? Picture
[b]Resonator, one of three. Or as I like to call them, pieces of plastic that now take up space in my garage.
[/b]
Nope. I put a K&N FIPK intake on so all the stock plastic came out. Even without the intake, I would leave the resonators off. The only purpose they serve is to quiet the intake which I don't consider necessary or desired. However, as stated above, make sure you close up all the outlets tightly if you do remove them. PVC caps work pretty well on the different size outlet holes from the stock box.
#40224 - 03/07/07 06:17 PM Re: What is this?? Picture
FSRBIKER Offline
Loc: Oak Ridge, NJ
You missed my point, why are you keeping them in your garage? I ditched mine soon after I had bought my X and tossed them right in the garbage. When I traded my X in they wouldn't even know to look to see if they were missing.
[b]Would you ever put them back??
[/b]
Nope. I put a K&N FIPK intake on so all the stock plastic came out. Even without the intake, I would leave the resonators off. The only purpose they serve is to quiet the intake which I don't consider necessary or desired. However, as stated above, make sure you close up all the outlets tightly if you do remove them. PVC caps work pretty well on the different size outlet holes from the stock box.[/b]
FSRBIKER
EOE...Opening Soon!
