0 registered (), 233 Guests and 0 Spiders online.
#41862 - 10/05/04 10:56 AM engine problem
3.3 V6/auto 1998
The truck is not able to accelerate and the engine cuts in and out like someone is turning the ignition on and off really fast, worse as I give it more power , or more power is required.
#1 problem only occurs when the truck is warmed up and gets worse the hotter the engine gets
#2 I had a check engine light for random cylinder misfires code 0701
#3 did the haynes test on the coil secondary and primary and the power transformer, all checked out, this test was done while the engine was hot.
Ideas?
#41863 - 10/05/04 02:25 PM Re: engine problem
rb42 Offline
Loc: McKinney
? I thought P0300 was random cylinder misfire, and 301 was cylinder 1 misfire... I couldn't find a 701 from a quick scan through... sure that is the correct code?
An injector pulse test will help determine if it's a faulty injector (but may not help determine if the spray pattern is off) - but injector testers are not cheap.. you can check the fuel pressure as well...
You can test the coil resistance on an injector on-car, or use a noid light on it to verify it gets power..
Assuming it's a specific cylinder, you could also look at the plugs for condition.(wet/dry/fouled/buildup/etc)
I'm not sure about that code however....
-=RB
PS - 701 Is a standard OBDII code for a powertrain/transmission control system error, but it's not specific.. and youre having misfire issues I think..
