0 registered (), 199 Guests and 0 Spiders online.
#426285 - 06/12/02 08:11 AM Shackles
Solar Offline
Loc: Massachusetts
Can someone give me the measurements for the center of hole to center of hole on Calmini shackles (or similar).
I would like to build my own and save the $50.00
Actually the width and length of the bars along with the hole sizes would be great also.
Thank you.
Alan
The reason why a dog has so many friends is that he wags his tail not his tongue!
#426286 - 06/12/02 08:13 AM Re: Shackles
Solar Offline
Loc: Massachusetts
I am sorry but I put this in the wrong section, I though I had selected the suspension section but it turns out I put it in the drivetrain section.
Can the moderator please move it to the suspension section.
Soooooorry
#426287 - 06/12/02 09:03 AM Re: Shackles
I doubt you could build them for less than $50.
Hardware will run you almost $25.
Finding the right sleeves may be difficult to fit the bushings correctly.
The shackles aren't straight either, they have a double bend in them, which requires a very large bender to make precisely.
Then you have to consider the time invested to make them...
Good luck. The measurments you need are already on your Xterra. Just add 2 inches hole to hole if you want a 1" lift (they sit at about a 45 degree angle).
