0 registered (), 128 Guests and 0 Spiders online.
#43573 - 29/10/06 09:40 PM Stuck in 3rd...
Well I went up to San Angelo this past weekend and my brother in law wanted to go wheeling. He (99 2500 4x4) and I (00 2WD X) went to his local trails and had some fun. We were traversing water that was at times hood deep (i know i should get a snorkel) but i had no problems with the engine breathing. After about half an hour of trail driving and hill climbs, he took me to his big mud pit. Well I went in and had some fun throwing mud everywhere and getting all nasty. Then on our way out from the trail, i notice the X doesnt have any umph to it at all, it felt like it was slipping hard in 1st.
Once i got on the road i stopped, pulled down to 1st and slowloy accelerated, it acted the same as before, i slipped into 2nd and nothing happened then into drive with O/D off, again nothing, then i hit O/D and nothing happened again. So i assumed 3rd. I took it to a car wash and cleaned it down then checked under the hood for leaks or anything. Sure enough, there is a very small leak between the transmission and the block...is never had a leak before.
while i was washing and checking it, it was turned off. Then i get back in, turn it to 'acc' and the O/D was blinking very fast...then off. So i started it and began to drive back to my hotel and what do ya know, it drove fine, all gears worked fine, only a small vibration in 1st during deceleration. After a little drive, the vibration was gone.
Today i drove it back from San Angelo to San Antonio which is about a 3 1/2 hour drive...no problems at all aside from that small leak.
Anyone have any idea's what the hell happened? Will is be a problem later? Is there a 'quicker/cheaper' way to fix the small leak without having the seal redone?
#43574 - 30/10/06 09:54 AM Re: Stuck in 3rd...
Is the leak tranny fluid or motor oil? Sounds like the rear seal(motor) or front seal (tranny). I doubt whether either of them are fun jobs.
The tranny issues sounds like a dirty electrical connection. Get under there and clean everything off then pull all the electrical connections and clean them. Then fill them up with silicone GREASE before putting them back together.
