0 registered (), 83 Guests and 0 Spiders online.
#44387 - 22/03/05 05:39 PM what rear axle i have
Ok i have a 2003 xterra 4x4 looking into locking the rear but what axle do i have????
Locker suggestions???
Thanx
Daniel
#44388 - 22/03/05 05:47 PM Re: what rear axle i have
Daniel-
You should have a H233B 33-spline rear axle. At this time, nobody is making a mechanical locker for the Xterra. If you really wanted to get carried away, you could go with a replacement of your 33-spline axles with some older 31-spline Nissan axles (you are looking for ones with Drum Brakes and ABS, older Frontiers are the best bet), and then you could go with a Lock-Right or Detroit locker. Check out: 4x4parts.com mechanical lockers
Your only real option now, other than going with a LSD on the rear (and f ront !) is to put in an ARB air locker. Expensive option, but its all that's out there. Good luck! [Uh Oh !]
#44389 - 23/03/05 08:16 AM Re: what rear axle i have
who makes lsd for mine
I wish AUSSIE WOULD !!!! i just put mine on my TJ best mod since my rear arb ! it helped me win a Mile Marker winch this past sunday
#44390 - 23/03/05 09:11 AM Re: what rear axle i have
Look at the diff, and see if it has a "Use LSD Oil" sticker/tag on it...if it does, you have a factory LSD (Was an option, std on SE I think).
That changes what options you have.
The factory LSD is pretty bad compared to the tighter aftermarket options....and limits what you can replace in the carrier, etc.
