0 registered (), 69 Guests and 0 Spiders online.
#44741 - 20/06/04 05:57 AM Add'l Oil and Trans Cooling when towing?
We just got a 2004 4x4 with AT. There were no options for additional engine oil and trans coolers for towing. We'll end up doing some light towing but it will be 10 hrs in 90+ degree weather and some in hills/mountains. After some break-in period I'll change everything to synthetics which will help a tiny bit. What towing experience do others have regarding need for or addition of extra oil coolers for the engine or trans? Thanks for the help.
#44742 - 20/06/04 08:31 AM Re: Add'l Oil and Trans Cooling when towing?
Forgot to mention it's the 3.3L V6 (not supercharged).
#44743 - 20/06/04 09:31 AM Re: Add'l Oil and Trans Cooling when towing?
An external transmission cooler is inexpensive and absolutely worth doing. You can purchase a cooler for about $50-60 and install it yourself, or get the whole shebang taken care of at Uhaul or the like for (well) under $150 total.
#44744 - 20/06/04 08:01 PM Re: Add'l Oil and Trans Cooling when towing?
BurgPath Offline
Loc: Knoxville, Tn
Trans cooler for SURE! Its cheap insurance against any problem with over heating. Remember to leave the overdrive OFF while towing as well.
Kevin
- 2008.5 Titan SE 4x4
#44745 - 21/06/04 05:41 AM Re: Add'l Oil and Trans Cooling when towing?
warlock Offline
Loc: Springfield VA
can a transmition cooler be added to a manual trany?
http://fotologue.jp/donnieandjemie/
#44746 - 21/06/04 07:13 AM Re: Add'l Oil and Trans Cooling when towing?
Not really, there's no mechanism to circulate fluid to it and you'd have to tap the case for in/out points even if you wanted to set something up with an electric pump or the like. It's not needed anyway, the MT shouldn't see temps high enough to harm it.
#44747 - 21/06/04 09:28 AM Re: Add'l Oil and Trans Cooling when towing?
warlock Offline
Loc: Springfield VA
cool thanks
#44748 - 29/06/04 09:32 AM Re: Add'l Oil and Trans Cooling when towing?
Thanks for the feedback. I've posted a request for any specific cooler make/model recommendations over in the 'Manufacturer Row' forum.
#44749 - 29/06/04 02:14 PM Re: Add'l Oil and Trans Cooling when towing?
Not really the right place for that, should have continued here.
