Can be done at home/ on the trail.
1. Lift and support the front end w/ jack stands
2. With engine cool, remove front skid and/ or any forward aftermarket skids.
3. Remove the wheel on the side that failed.
4. If you have some form of a 14mm socket or wrench that can get in there, then it will be easy. If not, then you need to drop the front end just a little.
5. There are 4 17mm bolts. Two in the front on the cross member, and two behind near the T-bars. We found 3 of the 4 bolts to be different lengths so mark and/or don't mix them. Support the front diff on your factory jack and then lower just enough to get your 14mm in there to the two lower motor mount bolts. Be sure to watch the CV boots as to not tear one.
6. The one upper motor mount bolt should pose no problem getting to.
7. If you are at home, use a hoist to lift the engine ~1 inch. This is enough to slide out the entire motor mount. If on the trail, use your buddy's stock jack to lift the engine from the bottom. **Remember that the other side is attached, so don't go further than you need!!**
8. Install the new motor mount, lower the engine and bolt up the motor mount tight. Don't forget to tighten any of these bolts! Lift the diff back up and reinstall the four bolts remembering which ones went to what. Attach wheel and skids and lower the truck.
9. All done. Should 1-1.5 hours at home with help. ~2+ on the trail with help.
Be carefull and good luck.
Troy
