0 registered (), 83 Guests and 0 Spiders online.
#494386 - 01/01/10 04:45 PM Lifted X, stock jack and jack location. what's in yours?
slantyshanty Offline
Loc: Northern Michigan
Just curious what you have in your stock jack location if you have lifted your X. Also curious where to put this topic? I put it here because I moved my ARB compressor to that location. I used to have it mounted like this:
because I didn't have speakers back there and never thought I would again.
Well, I had a few days off of work and decided to change some things up a bit. (and put my stereo back in the X, driving with no tunes sux)
Took it out of there and put it...
There.
Had to trim the tray a little on the underside but nothing a dremel couldn't fix.
So what's in your's?
#494394 - 02/01/10 01:05 PM Re: Lifted X, stock jack and jack location. what's in yours? [Re: slantyshanty]
granitex Offline
Loc: Columbus. Oh
What compressor are you using? and have you had any locker spit in that location?
Just curious since I need to mount mine, and was looking at the same place.
#494396 - 02/01/10 06:38 PM Re: Lifted X, stock jack and jack location. what's in yours? [Re: granitex]
I just put it there two days ago and haven't had a real chance to use it. I never noticed any fluid where it was mounted. In the jack location, it seems pretty waterproof or at least easy to clean up if it does spit.
#494408 - 03/01/10 05:17 PM Re: Lifted X, stock jack and jack location. what's in yours? [Re: slantyshanty]
ShoxX Offline
Be carefull putting it there. It seems waterproof but if the seal on your rear hatch starts to leak that where the water will go. I had a mildew smell in mine for months and could never figure out where the water was tell on day I decided to look in there. Had 4 inches of water in the tub.
#494411 - 03/01/10 06:35 PM Re: Lifted X, stock jack and jack location. what's in yours? [Re: ShoxX]
Casper Offline
Loc: Truckee,Ca
Nice looking work. I do have a question though. Why get rid of the jack? I mean I know that having a highlift is good on the trail for tons of reasons, but when changing a tire, or lifting the tire off the ground to reset a bead (which seems to be my main issue, I think I need to run a higher pressure when off road) I use the stock jack. It's just easier. When placed on the axle, instead of the body it works fine.
Casper
Porthos
2000 Xterra with a few mods.
