0 registered (), 92 Guests and 0 Spiders online.
#495189 - 09/03/10 02:59 PM 2000 X with blown motor suposedly
BIGJIM Offline
is it true that when timing belt of 3.3 v6 goes is the engine shot or or just needs timing belt replace and is it possible to put a 99 pathfinder v-6 in a 2000 X[size:17pt][/size][font:Impact][/font]
#495192 - 09/03/10 03:57 PM Re: 2000 X with blown motor suposedly [Re: BIGJIM]
e207 Offline
Loc: Ashland, PA U.S.A.
If the belt broke, and the engine was shut down, there is a good chance that there was no damage, you will have to search, unless someone answers, to find out, I cant recall if the vg33 is an interference engine or not. search some sites, I am sure you can find lots and lots of info about that subject, I know I've read a few things related to that topic.
As far as putting a 99 pathy into it, not sure that would be very cheap or easy, would probably cause conflicts if not changing the computer out too...
2002 SE/SC R.I.P. March 2015
Bielstien's
Shrock Sliders
Captain 38-90
#495212 - 10/03/10 10:52 AM Re: 2000 X with blown motor suposedly [Re: e207]
brian74d Offline
Loc: Palm Bay, FL
the VG33 in an interference engine, meaning that is the belt broke and you were at speed, there is a very good possibility that you may need to have headwork done.
2002 Xterra SE (3.3 Auto 4x2)
If you're surrounded, it only simplifies your problem.
#495235 - 11/03/10 09:11 AM Re: 2000 X with blown motor suposedly [Re: brian74d]
swampwrecker Offline
Loc: Brunswick, GA
Not sure about the VG33 being an interference engine. Check out this thread for an explanation.
http://www.nissanoffroad.net/messageboard/index.php?topic=7354.0
-Michael
Michael Girardo
East Coast Xterra Challenge
swampwrecker@ecxc.com
#495433 - 29/03/10 09:35 PM Re: 2000 X with blown motor suposedly [Re: swampwrecker]
Happy Birthday Kaiser Offline
If the pathfinder had the VG33E motor (likely) then it should be a drop-in replacement.
#495434 - 29/03/10 09:42 PM Re: 2000 X with blown motor suposedly [Re: swampwrecker]
-Michael
Well Barry certainly knows his chit (I used to live a block away from him... helped me with all kinds of stuff), but I swear I've seen posts on here about the pistons on the X hitting valves even though it has those cut-out pistons
