Originally posted by Xterrible:
Do we really need to elaborate here since it's already been mentioned that the 4WD section has it all covered?
:rolleyes:
If the hubs are unlocked, you can switch into 4wd at up to 25mph, and there will be a thud - pull the lever back quick. If the hubs are locked you can switch into 4wd at any speed, but make sure they are locked before you try it at high speeds. To switch into 4L you should be stopped. Check the 4wd forum for more info.
