#49815 - 27/02/05 09:50 AM Transmission Fluid Change
Is there a filter there that can be replace. read somewhere that there was a screen or something. so do i just clean the screen or is it just safe to drain the pan and add new fluid, without taking the pan off.
#49816 - 27/02/05 04:25 PM Re: Transmission Fluid Change
John Doe Offline
Loc: Chattanooga
What I do every 30K is:
1. Drive X to warm tranny fluid.
2. Drain fluid from drain plug in tranny pan.
3. Refill with approx. 3 3/4 quarts fluid.
4. Drive X around to mix fluid.
5. Repeat drain and fill, replacing washer on drain plug with an engine oil pan drain plug washer.
6. Drive X around to warm fluid.
7. Check and adjust fluid level.
Some people spend about $100 for a professional flush, but IMOA it's a waste of money.
#49817 - 27/02/05 09:07 PM Re: Transmission Fluid Change
Try the Backyard Mechanic section.
The change gets closer to 5 of 9 quarts if you jack the right front corner up a bit.
