0 registered (), 276 Guests and 1 Spider online.
Page 2 of 2 < 1 2
#498692 - 13/03/04 09:43 PM Re: Who has serious intentions of a solid axle?
Aero Steve Offline
Originally posted by FSRBIKER:
Brian what makes you think a H233B up front will be stronger than a Dana 44? With all the easy to find upgrades for the Dana 44 you could esily build a bombproof axle for a lot less than any Nissan front setup will cost. All those Early Broncos and Jeeps don't have problems and they are running much stronger motors than the Xterra will ever have.
I'm not convinced the Dana 44 is the way to go. For the gear ratio we need the pinion gear is pretty small. It's also kind of narrow if you are going to much larger tires. I'd want to fit at least 35" tires if I did this my truck.
#498693 - 14/03/04 12:14 AM Re: Who has serious intentions of a solid axle?
Axle Offline
Loc: Fort Carson, CO
Don't count on it from Calmini then. From the times that I've talked to Steve about it he insists that all we need is a spring under setup with enough room for 33's.
Axle
#498694 - 14/03/04 06:48 AM Re: Who has serious intentions of a solid axle?
DesertHB Offline
Loc: Huntington Beach, CA
Axle
This is the set up that I want. For at least the next 4 years my Xterra is going to be my primary vehicle (after that I may get a car for every day driving). I want a solid axle for strength and decent articulation, but I still need it to be very street friendly. Who knows maybe down the road I would go with 35s, but based on our wheel well size unless you want to get out the saw (and/or start playing with fiberglass) 33s are about it.
Doug
#498695 - 14/03/04 09:42 AM Re: Who has serious intentions of a solid axle?
Aero Steve Offline
[b] I'd want to fit at least 35" tires if I did this my truck.
Axle[/b]
I never said I was waiting on Calmini for a SAS kit. I figure I'd need a body lift and liberal use of a sawzall at that point with Dana 60/70's to move the tires further out. Also with the Dana series you can gear them lower than 5.13:1 for larger tires.
#498696 - 14/03/04 10:52 AM Re: Who has serious intentions of a solid axle?
Saline Offline
Loc: Fruita , CO
A dana 60/70 would be serious overkill for the X. Thats a lot of unsprung weight.
Desert Solitaire
#498697 - 14/03/04 11:47 AM Re: Who has serious intentions of a solid axle?
Kinetic Offline
Loc: Bristol, Tn
Overkill for your application maybe wink
- Bryan
#498698 - 14/03/04 11:51 AM Re: Who has serious intentions of a solid axle?
Kinetic Offline
Loc: Bristol, Tn
As long as you are using a Low Pinion 60 you can go all the way to 7.17's. The HP Ford 60's cut off at 5.13 like our H233B does. frown
- Bryan
#498699 - 14/03/04 02:39 PM Re: Who has serious intentions of a solid axle?
Axle Offline
Doug
I've already cut the fenders to fit the 33's I have on there now. If I'm going to do a SAS then I want to run at least 35's and preferably 37's.
Axle
#498700 - 14/03/04 06:00 PM Re: Who has serious intentions of a solid axle?
Aero Steve Offline
I've already got tires that measure out to 33.1" on stock rims. I'd like to get the ground clearance up with a spring over in the rear to go with whatever's up front. I'd move the tires out to compensate for the higher CG. Dana 60/70 get wider than Dana 44's I've found. I'm tempted to weld the rear doors and open up the rear wheelwells.
#498701 - 14/03/04 08:39 PM Re: Who has serious intentions of a solid axle?
DesertHB Offline
Steve,
I’ll bring my Ready Welder and sawzall to Moab. We can do the work at the condo. I’m sure it will end up real nice especially after a few pints. laugh
See you in Moab.
Doug
#498702 - 19/03/04 02:55 PM Re: Who has serious intentions of a solid axle?
the3cotes Offline
Loc: fitchburg
I already have a D44 out of an 81 Waggy. Louisville offroad outfitters had a kit for the Xterra.It was hangers and shackles and a list of parts that you needed to add.But for some reason they don't list the kit anymore.
#498703 - 19/03/04 03:05 PM Re: Who has serious intentions of a solid axle?
That was Plush Fabs pile of shit "kit", lucky for you (and everyone) it's not available.
#498704 - 19/03/04 11:01 PM Re: Who has serious intentions of a solid axle?
To go through all of the effort to go solid axle and then to swap in a D44 sounds kinda like a waste to me. A D44 and a D30 use the same diameter axles, the 44 just gets bigger tubes and the bigger R&P (and here's a hint, the R&P on the D30 isn't the weak point).
I can destroy a D44 axle shaft on command. 4lo reverse and back up against something that won't move and ::POP:: there it goes.
If you seriously wheel your X and you go D44 you'll be kicing yourself within a year for not going D60.
I know alot of D44 axles can be bought for the price of a 60, but it saves in headaches and downtime.
As for a D70 front, that's just plain old overkill, not so much for the strength but just for the weight factor. A D70 rear weighs about 475 lbs and a front weighs in at about 550. If you're going that far might as well just do rockwells.
Justin
#498705 - 20/03/04 01:01 AM Re: Who has serious intentions of a solid axle?
Maybe you shouldn't try that ?
Putting enough force against any axle shaft will eventually break it. Strength is great but sometimes you just have to know how to drive.
#498706 - 20/03/04 07:24 AM Re: Who has serious intentions of a solid axle?
Paco Pico Offline
Loc: Gig Harbor, WA
You are right it isn't the R/P, it is the U-joints on the axle shafts.
The Dana 30 uses 5-260X U-joints
The Dana 44 uses 5-297X U-joints (the 297's are stronger)
The Early Bronco 44's used the 5-260X shaft/joint combo, and can be upgraded to the 5-297X shaft/joint combo (If you were going to use that axle).
FWIW, in a Dana 44 with Warn shafts, and CTM 5-297X U-Joints would be near impossible to break in an Xterra.
#498707 - 20/03/04 11:01 AM Re: Who has serious intentions of a solid axle?
Axle Offline
If you want to save yourself about a grand at first just to get it done then putting a 44 up front wouldn't be a bad idea. Unless you're doing something really hardcore i.e. Rubicon or the like, then the 44 will more than likely take it. Or like Ian said, unless you just don't know how to drive.
Axle
#498708 - 20/03/04 04:24 PM Re: Who has serious intentions of a solid axle?
Riad Offline
[b]You going to ship your truck to him or fly him here?
.....That's too much to coordinate w/ the overseas guy, his concerns are the axle width (pretty much fixed by the donor axle in the first place), pumpkin offset (somewhat flexible), and caster/pinion-angle (the most crucial part of his work).
Brent[/b]
Well, that's the crucial part arright! Can you rotate the knuckles on that Axle? Does the drive shaft have CV or regular U joints on the other end. 100% Nissan sounds cool to me. Whes are you starting, 2 years from now?
Riad
#498709 - 20/03/04 04:37 PM Re: Who has serious intentions of a solid axle?
[b]I can destroy a D44 axle shaft on command. 4lo reverse and back up against something that won't move and ::POP:: there it goes.
Putting enough force against any axle shaft will eventually break it. Strength is great but sometimes you just have to know how to drive.[/b]
I'm not talking about long term power output, i'm talking about just getting off the clutch in 4lo if the truck is against something that won't move like a low stump or the like.
I also don't do it seeing as how axles cost more than i want to spend, it was just a bad day.
As for the different u-joints in a D30 and a D44, i know newer D30's can accept the D44 size just like a D44 can accept a spicer 760.
Justin
#498710 - 20/03/04 06:47 PM Re: Who has serious intentions of a solid axle?
Just noticed this:
FWIW, in a Dana 44 with Warn shafts, and CTM 5-297X U-Joints would be near impossible to break in an Xterra.[/QB]
Lets do some math:
D44-$200
CTM U-joints-$185 (x2)
warn axles:
R inner-$205
L inner-$165
Stubs -$115 (x2)
$1070
If you're willing to spend that much then $1K for a Ford D60 (about $300 for a chevy D60) should be pretty easy to swallow.
Justin
#498711 - 20/03/04 08:10 PM Re: Who has serious intentions of a solid axle?
The Nissan H233B front has Birfield-style (same as Toyota) joints at the ends. The knuckles can't be rotated without cutting the ends of the tubes, but since my idea involves swapping the ends of the axle tubes from one side to the other, the caster can be set at that time.
#498712 - 21/03/04 11:28 PM Re: Who has serious intentions of a solid axle?
Aero Steve Offline
Where do you get that price? I've got a '83 Chevy D60 in the driveway that cost $900 and that was the lowest I've seen around here. With gas to go get it I was getting close to $1K
#498713 - 25/03/04 03:46 PM Re: Who has serious intentions of a solid axle?
I can get a chevy D60 around St. Louis for around $300, just have to shop. Look for a junkyard that charges flat for a part. Where i go a rear axle runs just over $100 and a front runs about $250. They might not have the axle you want the day you need it, but if it's a long term project you can get some real steals.
Justin
#498714 - 25/03/04 03:59 PM Re: Who has serious intentions of a solid axle?
Our local Pull-N-Save has $10 for 10 Feet events every month or so. If you can carry it 10 feet, it's $10.
Big burly guys have left there with axles and engines for $10.
#498715 - 25/03/04 04:17 PM Re: Who has serious intentions of a solid axle?
OnlyOneDR Offline
Our local Pull-N-Save has [b]$10 for 10 Feet events every month or so. If you can carry it 10 feet, it's $10.[/b]
That's sweet! I need to find a local place that does stuff like that!
http://www.noas4x4club.com/
#498716 - 25/03/04 05:23 PM Re: Who has serious intentions of a solid axle?
FSRBIKER Offline
Loc: Oak Ridge, NJ
If anyone is looking for a Dana 44/9" combo out of a 69 Ford pickup let me know, I bought the NP435 trans for my 69 Bronco from him and he is about to junk the truck.
Personally a Dana 44 is PLENTY strong for a Xterra, there are plenty of Early Broncos that run 35" tires and up without problems. These trucks also have MUCH more power than an X does, extremely low gearing is common(I have a 6:69 first gear) so IMO a Dana 60 is overkill for the X.
FSRBIKER
97 TJ, 2" lift, 32's
EOE...Opening Soon!
Page 2 of 2 < 1 2
