Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 214 Guests and 1 Spider online.
Page 2 of 3 < 1 2 3 >
#498967 - 04/04/06 08:22 PM Re: Hmmm SAS
Looking good
#498968 - 04/04/06 08:53 PM Re: Hmmm SAS
looking good you up for carnage on saturday
#498969 - 04/04/06 09:03 PM Re: Hmmm SAS
It really looks great Kev, [ThumbsUp] [ThumbsUp] once again. Now go with Cameron and get some pics on the rocks laugh .
#498970 - 04/04/06 09:08 PM Re: Hmmm SAS
Holy crap! [ThumbsUp]
You went with revolvers too? How level does it sit and with what rear springs? The Calminis? Articulation is going to be sick!
Great job; I love seeing stuff like this.
#498971 - 05/04/06 04:34 AM Re: Hmmm SAS
steinism Offline
Loc: spooner street
do you have a 2"BL and 33's on there?
do you think your drag link should sit on top of the pitman arm? it's not in line with your trac bar.
looks sweet.
#498972 - 05/04/06 06:30 AM Re: Hmmm SAS
Kev that looks awesome!!! Can't wait to be part of giving that blue some character (rock dings, scratches,etc). Hopefully this will be a good summer of wheeling! laugh
"do you think your drag link should sit on top of the pitman arm? it's not in line with your trac bar."
The fellas doing his work are fairly skookum at building these rigs. Maybe putting it on the topside of the pitman will exceed the heim's limits at full extension. However, it does make a huge difference making the trac bar and the drag link parallel. Otherwise, every time you hit a bump the steering wheel will have to be moved to keep the truck going straight (bump-steer).
examples:
Not lined up (the top two links)
Closer to lined up
#498973 - 05/04/06 06:38 AM Re: Hmmm SAS
looks sweet.
Drag link is actually under the pitman you may be looking at the pic of the knuckle setup.
Yep 33s and the 2" body lift.
#498974 - 05/04/06 07:02 AM Re: Hmmm SAS
steinism Offline
Loc: spooner street
[b]
[/b]
confused
#498975 - 05/04/06 07:27 AM Re: Hmmm SAS
steinism Offline
Loc: spooner street
i'm not questioning the shops skills but as you mentioned bump steer and turning radius can be an issue if they are not parallel with one another. just an opinion. no attacking from here.
#498976 - 05/04/06 07:52 AM Re: Hmmm SAS
Hey Kev,
I'm new to the X. I come from a Jeep background and I am familiar with the Revolver Shackles. On a Jeep Wrangler (YJ) the hinge of the revolver shackle should point toward the axle. This goes for a front or rear application. Yours is pointing away. This may be correct for the your application but it goes against the basic design as I understand it. It's worth double checking. Here is a pic on the rear of a Wrangler.
#498977 - 05/04/06 01:31 PM Re: Hmmm SAS
yah i made that mistake also i put it on backwards it will work but it bounces and hites your frame might want to change it around
#498978 - 05/04/06 05:22 PM Re: Hmmm SAS
[b]
[b]
[/b]
confused [/b]
WOW!!!
Note to self: Do not answer any question that requires more effort than farting if you are tired and really need a cup of coffee.
Oh and thats the way it is suggested... plus most of what I have read says you want the drag link as close to horizontal as possible.
#498979 - 05/04/06 05:26 PM Re: Hmmm SAS
Yep I thought it was suspicious from the beggining with the zerk sticking out the back. Then I stopped on the way home and eyed another set and I will get em switched up.
#498980 - 05/04/06 05:50 PM Re: Hmmm SAS
what size tires are you planning on running imwondering if i can fit 36's with my 3"body
#498981 - 05/04/06 06:32 PM Re: Hmmm SAS
I upgraded the diffs to 5.13 and 5.14... so I am shootin for 35s after this set finishes out.
#498982 - 07/04/06 10:59 PM Re: Hmmm SAS
G0damn, Kevin...
[Finger] [Finger]
Did I mention? [Finger]
[Crybaby] [Crybaby]
How do I do mine from out of state?
[Rainbow]
#498983 - 12/04/06 06:07 PM Re: Hmmm SAS
So how's the SAS doing. You've had a week were's the PICS from your first offroad test? laugh
#498984 - 12/04/06 06:51 PM Re: Hmmm SAS
He just got his front drive shaft on. He was running around restricted with 2wd.
#498985 - 12/04/06 08:32 PM Re: Hmmm SAS
We're goin out tomorrow smile
#498986 - 12/04/06 10:05 PM Re: Hmmm SAS
Hey dont get your panties in a ruffle we will get some pics tommorrow!!!!!!!!!
[Smoking]
#498987 - 13/04/06 08:25 AM Re: Hmmm SAS
Cool, Just curious thought you forgot everyone because you were to busy wheeling. Have fun out there. [Too much XOC] laugh
#498988 - 14/04/06 01:47 PM Re: Hmmm SAS
steinism Offline
Loc: spooner street
how's your steering, turning radius and brakes performing.
#498989 - 14/04/06 02:19 PM Re: Hmmm SAS
Steering is great... it is alot easier to turn the bigger tires when aired down. I do have a little bump steer, but once again I got used to it. Maybe raising the track bar a little would fix it. Or a steering stabilizer.
Turning radius is about the same I just have to turn a little faster than before.
Brakes took a bit of getting used to.. but that is the difference of 20 years of technology. They felt soft at first but after I got used to the fact that I had to depress the pedal a little further I was fine.
#498990 - 14/04/06 02:21 PM Re: Hmmm SAS
what ever happened with the different shocks and springs you were trying out? and was that the front and the back?
#498991 - 14/04/06 02:47 PM Re: Hmmm SAS
The shocks did not match but I am running the Coils from King.
