Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 245 Guests and 0 Spiders online.
#553193 - 06/01/10 03:29 AM You CAN replace the rear wiper blade on 2005+ Xterra's
TripleJ Offline
There is an alternative to going to the dealer for a replacement rear blade on the 2005+ Nissan Xterra's. It may first appear that the blade and arm are one piece but if you take a look, you'll see the wiper blade can be replaced and its actually quite simple. It is a special wiper blade though. There may be other alternatives, but the 'Trico Exact Fit Rear Blade' available online snaps right onto the special rear arm and looks like the factory original. Much cheaper than the dealer alternative. Comes with removal and replacement instructions too. Hope this helps.
First Time Caller, Long Time Listener, Love The Show, Great Topic...Thanks For Taking My Call
#553194 - 12/01/10 06:36 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: TripleJ]
gRod Offline
Loc: houston, tx
you can always just get one from any regular parts place...autoZone, etc. and trim off the excess....viola!
#553195 - 19/02/10 07:26 PM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: gRod]
drebit Offline
Loc: Reno NV
You can do even better by going to a larger wiper blade. The stock 2nd Gen X rear wiper blade is 12 inches long. You can replace it with a 14 inch blade from the Murano.
It fits perfectly and clears more of the rear glass.
It's only money
#553196 - 02/04/10 11:17 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: drebit]
pinkyjones Offline
I've gotten OEM replacement blade that is exactly what Nissan uses for the Xterra. I got it online, think it was autowarehouse.com and if I remember correctly it was less than $20
#553197 - 16/04/10 11:27 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: pinkyjones]
TripleJ Offline
Be careful with this idea unless you're looking at replacing the rubber blade refill insert only and not the entire wiper blade assembly. I always replace the blade and frame because it goes through a lot of abuse during our wisconsin winters.
Yes, the Trico Exact Fit Rear Integral Blade comes in 12" and 14". I stick to the original size because I don't want to stress out my wiper motor, linkage or arm. As mentioned above, the wisconsin winters are brutal on wipers - especially rear wipers.
Yes, the trico is an exact OEM replacement without having to deal with the dealership!! I think it was about $12.
#553198 - 05/05/10 06:49 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: pinkyjones]
05_X Offline
Loc: Gloucester, MA
Thanks for the tip!
It's actually autopartswarehouse.com
I ordered Monday afternoon and was pleasantly surprised when standard UPS shipping got it to my house the next day. Turns out one of their warehouses is very close by!
Trico part # W0133-1854544 fits perfectly.
Cost about $10 + $5 shipping.
Edited by 05_X (05/05/10 06:51 AM)
Joined XOC: circa 2004
Pre Crash Post Count: ~2000
#672496 - 29/07/10 11:46 PM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: 05_X]
djfred Offline
I have just placed the order
thank you for the site
2005 Xterra SE
2 Wheel Drive
#672497 - 30/07/10 08:14 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: djfred]
PartsPeddler Offline
Loc: Richardson (Dallas), Texas, US...
#672498 - 30/07/10 08:45 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: PartsPeddler]
just have to pop the cover and take the bolt that holds it off. Easy and quick.
#672503 - 30/07/10 11:22 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: PartsPeddler]
djfred Offline
Originally Posted By: PartsPeddler
The price might be cheaper but the shipping is high.
Pretty much comes out to the same price.
And also over at autopartswarehouse store you can use a coupon code "APWCART" to save some $$
2005 Xterra SE
2 Wheel Drive
#672504 - 30/07/10 11:43 AM Re: You CAN replace the rear wiper blade on 2005+ Xterra's [Re: djfred]
It would probably make sense to buy up to 5 pounds worth of merchandise to offset the cost of shipping. Maybe get extra wiper blades, in-cabin filters, you know, stuff you need every year.
