0 registered (), 118 Guests and 1 Spider online.
#673032 - 13/09/10 08:58 AM transmission wow
paddlerborn Offline
Hi Guys,
2001 XE, 75,000 miles, auto. Running good, but noticed a very slight transmission "wow..wow" rythmical noise between 25 and 40 mph in 2 wheel or 4. Could be normal with all that stuff for 4X4 under there, and recently have not had Led Zep at volume 500 smile...so, do all Xterra's do this. Wheel bearings and trany fluid done several months ago and there are no leaks.
#673033 - 13/09/10 09:27 AM Re: transmission wow [Re: paddlerborn]
e207 Offline
Loc: Ashland, PA U.S.A.
Its kind of hard to imagine what your "wow..wow" might sound like , but I would start looking at the rears and drive shafts fisrt, unless you are certain it is from the tranny already.
2002 SE/SC R.I.P. March 2015
Bielstien's
Shrock Sliders
Captain 38-90
#673034 - 13/09/10 09:59 AM Re: transmission wow [Re: paddlerborn]
Photo Trek Offline
Loc: Winston-Salem NC
I think I know the sound you are talking about. If its what I'm thinking, you are probably getting ready to crap out your rear diff. An easy way to check this to to drain the fluid, but filter it with a shop rag as its going into your drain. When the fluid is all passed your filter look for metal bits. Check the magnet on the drain plug as well.
I've gone through two rear ends on two different Crown Victorias that made a very annoying "wow...wow" that got louder and more intense as it progressed. Apparently, there is an issue with the Ford axles they put in the CV's. I remember there was an issue with the rear ends on the early Xterras, but that should have made itself known by now if it was that problem.
Greg
www.446Photography.com
2000 Solar Yellow Xterra XE....Sold long ago
2010 Night Armor Xterra OR....Current ride
BFG AT KO's
#673090 - 16/09/10 10:42 PM Re: transmission wow [Re: Photo Trek]
paddlerborn Offline
Thanks guys, turns out it was the tires. The fronts were slightly cupped, so rotation did the trick. They are Yokohamas with a fairly agressive tread.
