Finally, plug the end you just cut with your 1.5" plug, just like you installed the previous plug. Then, reinstall the T-Pipe back through the fender wall and reconnect it to the air box. This is also kind of a PITA
THIS CONCLUDES THE REMOVAL OF THE SECOND RESONATOR
Finally, you will remove the baffle, located in between the inner and outer fender walls. For reference, the baffle is shown below; however know that YOU DO NOT HAVE TO REMOVE THE FENDER FOR THIS JOB. This picture was taken during a different project, and is shown merely for reference.
First, you will need to remove the four screws holding up the fender trim, as shown below. Use a stubby screwdriver for this
Now that the fender trim is removed, start pulling down and pushing in one the outer fender lining to create space.
If the clips become completely detached, reattach them in the following manner
Pull down the outer fender liner, as shown below.
Look up into the fender and make sure the front end of the baffle is detached from the inner fender wall. Reach up to the top of the baffle on the aft end and yank down. YANK ON IT!!!! Put your back into it. It is only held on with double-sided tape. You should see something resembling the picture below.
Crank your wheels hard right.Once you have detached both ends of the baffle, and after much coaxing, your fender will give birth to a brand new baby baffle. simply slide it out of of the wheel well as shown below.
Now, reattach the fender lining and the fender trim. Alright! You are done!
YOU HAVE SUCCESSFULLY REMOVED ALL THREE INTAKE RESONATORS. CONGRATULATIONS!!!
I am only going to recommend the K & N drop in filter. From my experience this filter has been absolutely wonderful. I always feel a HP gain and it is guaranteed to do so. I am not mistaking this for throatiness either. It does give the exhaust a deeper,meaner sound which you will dig. Also, there is an increase in gas mileage that has been noticed in both my vehicles. It has been tried and true numerous times. One of the best things about it, is that there is a million mile warranty. This filter is completely re-usable and I would never go back to a stock filter after this and I just put one in my MR2. I paid around $50 for it. Google it and price match it . Copy and paste this part number.
K & N air filter (V6 Xterra VG33 engine): 33-2031-2
Be aware 2" body lift owners, if you have not replaced your air filter since the body lift, you are in for a treat. It is a pain in the butt to get it to seal properly. Andy (WhiteX2000) suggested that I take an exacto knife and cut the "lip" off the filter to allow proper fitment.
But James...Will the oil from the K & N get on my MAF sensor and rend it inoperable!? No it won't
http://www.youtube.com/watch?v=UjwBiPm2W5Qhttp://www.youtube.com/watch?v=_SPd1...related&search=http://www.youtube.com/watch?v=HrU-s...related&search=http://www.youtube.com/watch?v=Ml8OI...related&search=Alright my friends! Happy modding!
DISCLAIMER, ADDING A K & N AIR FILTER WILL NOT VOID YOUR WARRANTY. I DON'T THINK I CAN SAY THE SAME ABOUT ALL THIS STUFF
