0 registered (), 165 Guests and 0 Spiders online.
#680363 - 01/08/13 06:37 PM Hearing a "popping" sound when wheels turned at extreme angles
Spoonman75 Offline
Loc: Missouri, USA
OK people,
I've noticed that when my '01 manual is at a stand still and I'm trying to turn that thing REAL tight and I go all the way to one side or the other of that rack/pinnion and then back off a little way (so as not to turn at the absolute extreme limit) I hear a strange LOUD popping or bumping?!!? Is this indicative of a CV joint issue on the front end or is this typical if you turn the wheels that far in one direction or another and start out from a stand still?? I suspect CV joint but this NEVER happens any other time. The X drives silently when turning and has no sounds when I turn any other time - only when extreme turn angles of the tires and mostly from a stop or REAL slow movement? Ideas? Experience? Does this sound like I totally made it up just to talk with you because I'm bored??
Thanks in advance!
Spoonman
Confuscius say: War does not determine who right - war determine who left!
#682404 - 05/03/14 06:32 PM Re: Hearing a "popping" sound when wheels turned at extreme angles [Re: Spoonman75]
legend869 Offline
Mine was doing this too. Never found a culprit but I suspect a ball joint somewhere.
