0 registered (), 227 Guests and 0 Spiders online.
#682610 - 10/08/14 03:42 PM 2000 XE A/C selector switch
david66 Offline
Loc: Tampa Bay Area
The a/c is either off or full blast... how much of a pain is it to change the selector switch yourself? And what website would I order the part from?
Edited by david66 (10/08/14 03:43 PM)
#682612 - 11/08/14 07:54 AM Re: 2000 XE A/C selector switch [Re: david66]
BradLee Offline
Loc: Black Hills
There was a couple AC problems known to the 2000. Are you saying the selector knob feels like it is pulling/pushing against something when you turn it, or does it feel weak when you turn back and forth, or does it feel normal but AC will only function wide open?
The search function is "BROKEN". Wish I could put jumper cables to this ol' XOC.
#682619 - 13/08/14 05:39 PM Re: 2000 XE A/C selector switch [Re: BradLee]
david66 Offline
Loc: Tampa Bay Area
The knob switches between 1-4 fine, but the compressor and fan only come on on 4 (full blast). I ordered a resistor, I hope this is the fix, and I understand it's right behind the glove box? Hopefully a quick fix...
#682624 - 13/08/14 08:59 PM Re: 2000 XE A/C selector switch [Re: david66]
BradLee Offline
Loc: Black Hills
Send feedback when completed ?
#682628 - 15/08/14 05:15 AM Re: 2000 XE A/C selector switch [Re: david66]
That's typically the fix. When the resistor goes, you progressively lose fan speeds until only highest is left...and that's what you seem to have.
I did a write up with step by step pics on how to replace that if you need it...but its pretty straight forward.
#682642 - 27/08/14 12:10 PM Re: 2000 XE A/C selector switch [Re: BradLee]
david66 Offline
Loc: Tampa Bay Area
Yep,5 minute fix, didn't even remove glove box!
