Hmmm ... this is interesting. I would like to think that the VG33 engine could withstand 3000 RPM in 4 Lo (especially in the winter), but I'm not sure. 3000 RPM for extended periods of time, with minimal air flow may cause the engine to overheat. I do most of my off roading in 4 Lo; at speeds less than 10 mph (most of the time less than 5 mph). I have never seen the temp gauge climb past the normal mark (not even in the heat of summer), but I almost never rev the engine past 1500.
I would check the coolant level and head back out on the course. Put it in 4 Lo and drive for 30 - 45 minutes; but this time keep the RPMs down around 1500. See what happens. If the gauge starts to climb past the normal reading, take it to the shop for a diagnosis. If there really is a problem, it could be any number of things ... thermostat, mechanical fan clutch, inoperable electric fan, etc.
Maybe 3000 RPMs for 45 minutes of slow speed driving is just too much?
You've got city hands, Mr Hooper . . . you've been countin' money all your life.
