Yesterday at 04:27 PM
#101226 - 06/05/02 10:23 AM Keeping it Slick?
BoarderPhreak Offline
Loc: Huntington, NY
Just curious...
If you don't use 4x4 for a while, does anyone drop it in and drive down the block a ways just to "get the oil sloshin' around" a bit, or does normal driving do enough of that? It is kind of thick oil in there...
#101227 - 06/05/02 11:20 AM Re: Keeping it Slick?
Lonnie Offline
Loc: Sacramento, CA
I think that Normal Driving would do enough of that. I hadn't been off roading for about a 8 months until 3 weeks ago, and I didn't notice any problems or anything.
Lonnie
nccx_n@msn.com
#101228 - 06/05/02 11:36 AM Re: Keeping it Slick?
Loc: Huntington, NY
That's what I'm thinking, with the thicker oil, and that it doesn't really get that hot (thinner) during normal driving.
I'm thinking more long-term, just to keep oil on the metal to prevent any rust or other corrosion.
#101229 - 06/05/02 01:46 PM Re: Keeping it Slick?
Put in 4hi as you start off, then right back in 2hi as you drive. That will lock the hubs and get everything from the t-case forward spinning. You want to bring everything up to full operating temp to drive out moisture and such. Let it go for several miles.
#101230 - 06/05/02 02:03 PM Re: Keeping it Slick?
Loc: Huntington, NY
Ahh, thanks Brent - that's good thinking. Keep the stuff in motion, but not fully in 4wd and then you can drive around on the road without breaking stuff. I was thinking just a straight line down the block, but letting it get fully warmed up, etc. sounds like a better idea.
Good tip!
