Ok,
The whole install of the half shaft took about 2 hours.
Tools required:
· 17mm socket for removing/installing the shock.
· 12mm for removing/installing the 6 bolts on the diff.
· Snap ring pliers
· 19mm for torsion bar bolt.
· 19mm box wrench for locking nuts.
· 6mm hex head wrench for hub removal
· Grease
The first thing I had to do was remove the hub. I just removed the 6 hex bolts, pulled the hub off to expose the snap ring.
Took the snap ring off and had to figure out how to remove the outer CV joint. I think the proper way is to drop to lower A-arm. What I ended up doing was just cranking down the torsion bars. As you can see from the photo the lower A-arm is in the way.
I lowered it as far as I could to get the best possible angle to take out the cv and install the new shaft.
Here it is removed.
Here it is installed through the hub not connected to the diff.
I then connected the other end to the diff.
I figured since I was taking apart the hubs, I ordered the Warn manual locking hubs and installed them.
Cranked the t-bars back up and I was done.
I would rate it moderately difficult but is all basically bolt on.
