Photos of what you have to cut/grind, last one is the upper shock mount gone. Same on both sides. E- mailed you the instructions to wajudoo@hot….. 8 parts ~8mb each so I hope you have broadband
Air tools make quick work of all the bolts. Really not that hard just tedious, I took the lower a-arms off as one piece and don’t separate them but wait until the cutting/grinding then the fun really starts
and sparks fly.
Get some good cutting blades for the sawzall & and several cutting & grinding discs for the angle grinder and you should be good to go.
Don't really need to worry about the tightness of the coil-overs just the ride height you're going for. Mine have 1" of threads shows on top and you leave 1/2" below that and set the stop for the coil bucket divider thing.
Good luck mang
get it done and come up and ride the 'Con with us 9/16-18
Brian
