I'm looking to SAS my X in the near future. Picked up the a 1991 Wagoneer D44 (62.5" WMS to WMS) that's I'm cleaning up.
Originally, I was planning on using the complete Calmini kit. After doing a bit of $$$ math I figured out that I wasn't going to have the budget to do it right so I started reading through most every thread in this section from the back forward. It took me about a month of reading a few threads a night. Mad props to all of you who've contributed information on the SAS process over the years. Lot's of good reading material.
Here are some of the notes I've complied from all the information you guys have provided.
**Revised 04/08/07**
SAS Kits
Calmini Coil-Over SAS Kit - $1795
*Designed for 10" coil-over shocks
*DIY - welding on the Axle only. Everything else is bolt on.
*Includes a skid plate that the other kits don't have
http://www.purenissan.com/solid_axle_swap2.htm All Pro kit - Universal (Taco) SAS kit - $1349
*DIY - welding to the axle and frame rails
http://www.allprooffroad.com/index.php?option=content&task=view&id=80 Off Road Solutions - 79'-95' SAS kit - $1573-$1772
*Designed for 14" coil-over shocks
*DIY - lots of welding
*Includes limiting straps that the other kits don't have
http://www.offroadsolutions.com/products/suspension.htm#79-95_coilover_systems Front Coil-Over shocks
Calmini Shocks
Fox 2.0" x 10" Travel Reservoir NP980-99-005A $285.00 each
Fox 2.0" x 10" Travel Emulsion NP980-99-004A $235.00 each
http://www.purenissan.com/new_page_3.htm Off Road Warehouse
Fox 2.0" x 10" Travel Emulsion 980-99-025-A 10.0 EMULSION $235.00
*best prices at Off Road Warehouse
*Call Off-Road Warehouse for better pricing than the visible online pricing.
http://www.offroadwarehouse.com/products/sfID1/12/sfID2/113/sfID3/97 Springs
Calmini Springs
Eibach 8" x 300 lbs./in. Coil NP12700-8C $65.00 each
Eibach 12" x 300 lbs./in. Coil NP12700-12C $65.00 each
Eshocks.com
Hyper Coils
Top Springs 8.00" Length 2.5" ID 350 LBS $55
http://www.eshocks.com/hyp_ind.asp?SubCheck=5+IDQ2%2E&Free_Length=Q8&SubChar=Q
Bottom Springs - 12.00" Length 2.5" ID 300 LBS $55
http://www.eshocks.com/hyp_ind.asp?SubCheck=5+IDQ2%2E&Free_Length=2Q1&SubChar=Q
Off Road Warehouse
Eibach
Top Spring - 0800.250.0350 8.00" Length 2.5" ID 350 LBS
Bottom Spring - 1200.250.0300 12.00" Length 2.5" ID 300 LBS
*eSHOCKS.com, Off Road Warehouse, & Calmini have almost the same pricing on Eibach springs - $65.00 each
*Off-Road Warehouse has best prices for call-in orders.
Driveshaft
Calmini CV Front Driveshaft NP12725 $400.00
http://www.purenissan.com/front_cv_shaft.htm Grassroots - CV shaft conversion for use with an XJ front Driveshaft - $120
http://grassroots4x4.com/index.php?page=...uemart&Itemid=1 *XJ front Driveshafts can be found on e-bay, craigslist, & ecology for about $25 - $40
*XJ front Driveshafts are very easy to replace because they are very inexpensive due to the volume that's available on the market
*XJ front Driveshafts may need to be shortened to fit the Xterra SAS configuration.
*How to notes -
http://nissannut.com/projects/Driveshaft/ Axles
Dana 44 - Front
Gears - General recomendations
4.89 gears for 31's - 37's
5.13 gears on 35's +
Manual Locking hubs for Dana 44
* 19 spline for Wagoneers 74-91
* Check e-bay, criag's list, & Buy/Sell areas for best pricing
Superwinch - SWI400518
Warn - 20990
H233B - Rear
HG46 - 2000-2001 is the H233B axle with 4.636:1 gearing (33 spline axles). Typically comes with an R200 front axle
HG49 - found in mid year 2001+ Frontiers and Xterras. H233B / R200 combo with 4.90:1 gears.
* Up to 5.143 gearing can be had for H233B's. AC & Nismo are the only companies offering gears. Supposedly the gears AC provides were originally designed for the 10mm bolt for the 31 spline H233B used on the Nissan HB and has them machined out to 12mm to fit the carriers for the 33 spline H233B used on the 2000 - 2004 Xterras.
Wheel Spacers -
All Pro-Off Road
1.5" Thick - 6" on 5.5 - 79 for a pair.
http://www.allprooffroad.com/index.php?option=content&task=view&id=19
