1 registered (Tom),
46
#166087 - 30/12/06 12:07 PM
Originally posted by BlueSky: Originally posted by Hawk: [b]You people just don't get it.....If the conveyor is matching the plane's speed, the wheels will just be spinning twice as fast as the plane is actually travelling. However, the plane will still be moving forward......Forward motion will give the plane the lift required to take off. You are all STILL hung up on the wheels vs the conveyor. There is a third force at work here....the engines. And, yet again, I'll say that the conveyor is not working against the engines [b]AT ALL! The engines are working completely independant of the conveyor....[/b] And you're hung up on thinking the plane is weightless. The wheels ARE exerting force on the conveyor - the weight of the airplane.[/b]That's great! I'm not arguing that. The force is being exerted downward, and not forward or in reverse.... Downward force will not affect the desired end result of forward motion unless the downward force is so great that the plane won't move regardless of what's under it. We KNOW that this is not the case, otherwise there wouldn't be flight...
#166088 - 30/12/06 12:08 PM
Loc: Georgia
Originally posted by XPLORx4: What does the weight of the plane have anything to do with forward movement? Try pushing your Xterra up a hill in neutral and then come back and ask again.
#166090 - 30/12/06 12:09 PM
Originally posted by Mobycat: Originally posted by XPLORx4: [b]What does the weight of the plane have anything to do with forward movement? It determines how much the engines have to work to get the thing moving forward.[/b]And there you go....it's moving forward...
#166091 - 30/12/06 12:10 PM
Loc: San Jose, CA
Originally posted by Mobycat: Originally posted by XPLORx4: [b]What does the weight of the plane have anything to do with forward movement? It determines how much the engines have to work to get the thing moving forward.[/b]So what if you just have some really huge engines?
#166092 - 30/12/06 12:10 PM
Originally posted by Mobycat: Originally posted by Hawk: [b]Back to your "rope is rope, not wind" comments Moby.... Is it just me, or does this look like a series of ropes travelling around the wing?!? You're kidding, right?[/b]You need to think more abstractly
#166093 - 30/12/06 12:11 PM
Originally posted by BlueSky: Originally posted by XPLORx4: [b]What does the weight of the plane have anything to do with forward movement? Try pushing your Xterra up a hill in neutral and then come back and ask again.[/b]In the scenario you're describing, you're pushing vertically, not horizontally...
#166095 - 30/12/06 12:11 PM
Loc: San Jose, CA
Originally posted by BlueSky: Originally posted by XPLORx4: [b]What does the weight of the plane have anything to do with forward movement? Try pushing your Xterra up a hill in neutral and then come back and ask again.[/b]Yeah, but this scenario isn't on a hill. It's on a level runway.
#166096 - 30/12/06 12:12 PM
OK. one more try. Kind of the opposite scenario posted by XPLORx4. Can we agree that one effect of the conveyor is to double the rotating speed of the wheels?
Imagine an aircraft on a long runway wtih a tailwind (FYI- a tailwind is counter-productive to the attainment of lift) of say, 120 knots. Exactly the airspeed needed by the aircraft to lift off. The aircraft begins takeoff roll, with the wind. The wheels spin faster and faster. The plane reaches 120 knots of groundspeed, and has reached zero airspeed. The aircraft continues to accelerate and reaches 180 knots groundspeed, which is 60 knots airspeed. The wheels are spinning at 180 knots now. The aircraft then reaches airspeed of 120 knots, which is 240 knots groundspeed, 240 knots of wheelspin. Lift can be achieved at 120 knots airspeed, and the plane takes off.
Those numbers in review: At rest on the approach end: Airspeed -120 [negative 120 knots] Groundspeed 0 wheelspin 0
starting takeoff roll: Airspeed 0 Groundspeed +120 wheelspin +120
Halfway to achieving lift: Airspeed 60 groundspeed +180 wheelspin +180
at liftoff: airspeed +120 groundspeed +240 wheelspin (before liftoff) +240
Now shouldn't the plane stay on the ground according to the "not-flyers'" logic?
#166097 - 30/12/06 12:12 PM
Loc: Georgia
Originally posted by Hawk: Originally posted by BlueSky: [b] Originally posted by XPLORx4: [b]What does the weight of the plane have anything to do with forward movement? Try pushing your Xterra up a hill in neutral and then come back and ask again.[/b] In the scenario you're describing, you're pushing vertically, not horizontally...[/b]Fine. Try pushing your Xterra on level ground and then ponder what weight has to do with forward motion. The force of gravity must be overcome to move an object, whether it's up, down, forward, back, or sideways.
#166098 - 30/12/06 12:12 PM
Originally posted by BlueSky: Assuming there is no wind, the plane has to move relative to the surrounding ground, i.e. whatever is next to the conveyor belt, to achieve flight. It's not going to do that if the conveyor is matching the aircraft's speed. The conveyor matching the airplane's speed will only cause the wheels AND the conveyor to rotate at twice the speed of the aircraft. Fact of the matter is the plane will STILL be moving forward regardless...
#166100 - 30/12/06 12:13 PM
Ok...how has gravity come into play now? It's not going to prevent an airplane from taking off. If that were the case, we wouldn't have flight! See my first post on page 26
#166101 - 30/12/06 12:14 PM
Loc: San Jose, CA
Originally posted by BlueSky: The force of gravity must be overcome to move an object, whether it's up, down, forward, back, or sideways. Uh, dude: Gravity only affects things in the VERTICAL dimension. You don't see apples fall from trees SIDEWAYS do you?
#166102 - 30/12/06 12:14 PM
Originally posted by Mobycat: FRICTION.
You guys are completely ignoring friction...... We are? I guess you missed the equations: Originally posted by JeffW: Instead of trying to convince everybody that the wrong answer is right, read the UNBELIEVIABLY simple physics of the situation.
Coefficient of dynamic friction:
Force of friction:
F(f) = -uN
(negative because it opposes motion)
u = coefficient of static friction
N = weight of plane
Notice velocity is not included!
That means that the velocity of the conveyor belt is irrelevant for all practical purposes.
F(t) is force of thrust
a = (F(t)+F(f))/m
You won't find a scenario where |F(f)| is greater than |F(t)|. Therefore, in ALL cases the plane moves with respect to the atmosphere, thus achieving lift.
Please stop being so bloody indignant and pause long enough to understand why the correct answer is correct.
#166103 - 30/12/06 12:14 PM
Originally posted by Mobycat: Originally posted by Hawk: [b] Originally posted by Mobycat: [b] quote: Originally posted by Hawk: And, yet again, I'll say that the conveyor is not working against the engines [b]AT ALL! The engines are working completely independant of the conveyor....[/b] The conveyor HAS to be working against the engines if it's matching the plane's speed.[/b] Dude...the only thing that can work against the engines is the air flowing through them. The conveyor is working on the wheels....[/b]FRICTION. You guys are completely ignoring friction. If the engines are off, and if there was NO friction, and that conveyor belt moved, the plane shouldn't budge - it will just have rolling wheels. But it WON'T. It WILL move backwards. What do you think a wheel is for, Moby? It's there to REDUCE FRICTION.
#166104 - 30/12/06 12:15 PM
Loc: Georgia
Originally posted by MattyX: OK. one more try. Kind of the opposite scenario posted by XPLORx4. Can we agree that one effect of the conveyor is to double the rotating speed of the wheels?
Now shouldn't the plane stay on the ground according to the "not-flyers'" logic? See, this is what I'm saying. Your argument rides on a tailwind of fixed velocity. In the scenario, the conveyor moves faster and faster as engine thrust is increased, so the speed relative to the surrounding air remains zero.
#166106 - 30/12/06 12:16 PM
AAARGGG!
The belt only moves if the plane moves....
Speed, or Movement, means relative to the world...not the belt.
My GPS will say I'm going 0 mph if I am on a tread mill that is turning at 4 mph.
If my tread mill MATCHES MY SPEED, it would be turning at ZERO MPH.
#166107 - 30/12/06 12:17 PM
Loc: San Jose, CA
(I think Moby and BlueSky still think the earth is flat, btw...)
#166108 - 30/12/06 12:17 PM
Originally posted by Mobycat: Originally posted by Hawk: [b]The conveyor matching the airplane's speed will only cause the wheels AND the conveyor to rotate at twice the speed of the aircraft. Fact of the matter is the plane will STILL be moving forward regardless... If that's the case - the conveyor is no longer matching the speed of the aircraft.[/b]There's a new invention in town. They call it the wheel! It rolls, even on conveyor belts!
#166109 - 30/12/06 12:17 PM
Originally posted by MattyX: What do you think a wheel is for, Moby? It's there to REDUCE FRICTION. Actually, the wheel bearings are there to make it a nearly frictionless scenario
#166110 - 30/12/06 12:19 PM
If my tread mill MATCHES MY SPEED, it would be turning at ZERO MPH. We tried to explain that to them but they are two busy defending the incorrect answer to read!!
