You probably won't believe this, but last time this came up there were several people that vouched for using peanut butter of all things, enough that I actually believe them. Only problem is you then have to clean off the peanut butter, which means you probably need to re-wax after the wash, which means you'll probably end up with wax on the plastic again...
Sounds like something straight out of "Dear Elouise!"
Ever see that Simpsons episode where Lisa gets gum in her hair, and Marge tries to take it out... With nearly everything in the kitchen? Hee hee.
But seriously... Can you scrape off these spots with a fingernail? Does it look like wax? Could it be paint kicked up from the road, perhaps? I've seen this happen - the highway department lays down fresh lines, but some yahoo just has to drive over it, misting the paint and kicking it up...
