A fuse or some fuses for the electric windows, rear defrost and cruise control have blown three times on my Xterra.
The problems began initially with the high beams flashing by themselevs, even when the lights were off. Then the fuse blew.
The dealer may have finally fixed the problem. They found a wiring harness that was being interfered with when the clutch was depressed, causing the fuse(s) to blow.
I am not sure if I should be pleased that they may have finally fixed the problem, or pissed off that I told them the problems were linked to the clutch in the first place, and it took them 3 times to bother checking it out.
Anyway, if anyone else in a 5 spd has similar problems, this might be the cause.
