I don't know the answer regarding the wiring, but I don't think a towing place would charge much to do that for you (maybe $50?). If you don't have the proper lighting control box you could have a problem. FWIW, the control box runs about $20 and my towing place replaced mine for free when it whacked out way past it's warranty period, so I don't think it was such a bad deal paying someone to do the job.
As far as the check engine light is concerned, it should reset eventually as long as the problem has been fixed. A lot of cars need to be restarted a certain amount of times before the fault is erased and I'm guessing that's the way the X works.
Good luck!
Originally posted by jbgeis:
Hi Everybody, My light came on tonight after monkeying with an electrical outlet under the passanger rear bumber. Supposedly, this is where I am supposed to insert the harness for the wiring of the tow hitch. Which brings up another point? Has anybody had problems figuring out the wiring of the tow hitch? I have the 5 speed manual tranny. I told the dealer that when I bought the harness. Why would this trigger the service engine soon light, even after I plugged the thing back in? Yes, my gas cap is tight. This light appeared after I unplugged the wiring. There is no question about that. All the lights worked on the entire car, even with the thing unplugged. What have I done?
(Don't flame me IAN, this is not covered anywhere in the forum, I checked this time!!)
2000 SE 4x4, Aztec Red
