#186545 - 20/02/01 10:17 AM Accessory wiring question
ned946 Offline
Is it acceptable to use the Xterra frame as the negative lead back to the battery when wiring accessories? I have noticed that some accessories just have the postive lead to the battery and the other lead is attached to the body/frame. Can you wire a heavy load through the frame?
#186546 - 20/02/01 11:46 AM Re: Accessory wiring question
EverythingZen Offline
Loc: Houston TX USA
The prefered and best way to ground anything is through the frame. I used the bracket for the battery for external lights. I don't know how high of a load your talking about, but a good rule of thumb is one gauge thicker wire than your hot lead.
00' Super Black SE
98' Jeep Wrangler
Sport
--The difference between a warrior and an ordinary person is that the warrior sees everything as a challenge while an ordinary person sees everything as a blessing or a curse.--
#186547 - 20/02/01 12:44 PM Re: Accessory wiring question
*paul Offline
Loc: New Zealand
Yes and yes, there should be no problem up to 50-100 amps roughly. More of a problem is finding a suitable threaded insert on the body and then scraping off the surrounding paint.
There is no need to use a different gauge for the supply and return.
-Paul
2007 Nissan X-Trail
New Zealand (ex San Diego)
#186548 - 20/02/01 07:40 PM Re: Accessory wiring question
ned946 Offline
Originally posted by EverythingZen:
I don't know how high of a load your talking about....
A rear mounted winch. Using gauge 2 wire.
Thanks for all the info guys!
#186549 - 20/02/01 07:51 PM Re: Accessory wiring question
BoarderPhreak Offline
Loc: Huntington, NY
The frame is generally perfect for most anything that needs grounding. One exception to this is the electronics of your audio system. I guess because the frame might induce noise into the system or something...
Moderator:  johngraves2
