AB since I have a digital camera and I don't seem to be able post pics right let me describe it to you and see if it helps.
The screw for positioning up/down is located on the front of the grill. You can access it through a small hole that is there. I used a flashlight to find it. Make sure your screwdrive is long enough to reach.
The side to side screw is located near the upper inside corner of the headlight. Nissan even provide a groove so the screwdrive will align properly. How thoughtful!
Let me know if this helps. If not, I will try to figure out how to post some pics or I can email some.
Scott
Math svcks!! -- Jimmy Buffett
http://www.gpxo.org CRIKEY!! That croc nearly bit my arm off!
[This message has been edited by DeFibVT (edited 07-09-2001).]
