#194907 - 17/07/03 11:21 AM Fluids?
I am getting ready to change all the fluids in my X. I would like to know if ya'll reccomend certain brands of fluids. I'd like to know what you guys use for differential (LSD), x-fer case, manual tranny, brake, engine coolant, and any other fluids there might be. Please help me out ya'll, I'd like to get it done this weekend and I'd like to use the best fluids for the job. Just in case you were wondering, I am doing my 60K maintenance.
Peace,
MooT
#194908 - 17/07/03 11:51 AM Re: Fluids?
This should help:
http://mywpages.comcast.net/xterra/tech/Diff_fluid_change.txt
Mobil 1 or any other synthetic is good for the diffs. I used Mobil 1 ATF for the transfer case too (note the warning in my how-to regarding the t-case)
Use a GL4 oil only for the tranny, NOT GL5. Hard to find. Apparently Redline MTL is OK though.
I used Castrol LMA when I flushed my brake fluid last week. Supposedly one of the best non-synthetic fluids around. I've heard bad things about Valvoline Synpower fluid as I recall. Start with the LR, then RR, the RF, then LF.
Coolant: Good ol' Prestone will do. Don't mix the long-life (like Dex-Cool) with the conventional type though. I'm not even sure if our engine is tolerant of the long-life coolants anyway, there are some issues to be aware of for it.
#194909 - 17/07/03 11:55 AM Re: Fluids?
Cygnus-X1 Offline
Loc: Alexandria, Virginia
I'm getting ready to flush my tranny with Redline D4 ATF which is Dexron3 compatible. Same stuff goes in the transfer case too. It'll take about 18 quarts total to do both (according to Brent).
For the Diffs: Redline 75W90 which comes with LSD additive. Takes about 5 quarts.
#194910 - 17/07/03 12:13 PM Re: Fluids?
austinbrtndr Offline
Loc: ATX
ok... so after buying all these fluids and filters and all, how much cheaper is it than taking it to the dealer? I think my dealer is a little expensive @ $500, but he changes fluids, greases bearings, etc... while I sit in the a/c...
XOC
www.myspace.com/kraigslist
Kraig
#194911 - 17/07/03 01:04 PM Re: Fluids?
Aero Steve Offline
I had my tranny flushed a couple months ago and the shop refused to use any brand of synthetic ATF. Their opinion is that even though synthetic may have better cooling properties, it is inferior as a lubricant. They felt using synthetic ATF would shorten the life of the tranny. Any comments?
#194912 - 17/07/03 01:51 PM Re: Fluids?
Sounds like baloney to me. I've got 40K since I had mine flushed with Mobil One at 30K and it's doing just dandy.
#194913 - 17/07/03 05:04 PM Re: Fluids?
Toy Man Offline
Loc: Beaverton Oregon
Double balony. The local Nissan dealer flushed by auto tranny and re-filled the auto and xfr case with Mobil 1 with no questions. That was 3 or 4 months ago. No problems.
Took 17 quarts.
Toy Man
Moderator:  johngraves2
