Yesterday at 04:27 PM
#195590 - 15/07/03 10:02 AM Thermostat Replacement
I need to replace the thermostat on my 2000 Xterra. Has anyone done this themselves? Is it fairly easy. Are there 'how to' manuals available online?
#195591 - 15/07/03 11:22 AM Re: Thermostat Replacement
Carlton McMillan Offline
Loc: MN
How do you know it is bad?
Yes it is a simple replacement. All you have to do is remove the hose going to it... unbolt it.. replace thermostat and RTV sealant and then put everything back together.
#195592 - 15/07/03 11:46 AM Re: Thermostat Replacement
wordtothis Offline
Loc: atlanta
and sometimes it helps to take come coolant out so that when you take the hose off, it doesn't drain out onto your hand or paint.
but other than that, mcmill is right on the money with that one. if you aren't sure that's the problem, take it off and test it by putting it in boiling water, if it opens, then you may not need to be changing the thermostat.
laters,
d [Geek]
#195593 - 15/07/03 01:32 PM Re: Thermostat Replacement
Thanks for the information guys. I had another look under the hood and there's a whole pile of stuff that has to be taken off before I can get at the thermostat cover. Is it as simple as taking all that stuff off first. Some of it, including a black transverse mounted plate with a seal looks kinda important. Any thoughts?
#195594 - 15/07/03 02:13 PM Re: Thermostat Replacement
Loc: MN
You don't have to take any of that off to get to the thermostat.. just use the right sized socket with extension.
#195595 - 16/07/03 02:07 PM Re: Thermostat Replacement
T&T There's a PM waiting for you.
#195596 - 19/07/03 02:42 PM Re: Thermostat Replacement
poe67 Offline
Loc: Bar Harbor, ME
I am looking for directions or tips on this also.
Thanks in advance.
I came, I searched, I found, I fixed.
#195597 - 26/07/03 06:28 PM Re: Thermostat Replacement
drspencer Offline
btt
#195598 - 09/08/03 06:20 PM Re: Thermostat Replacement
ChuckH Offline
Carlton makes it sound easy but it's not; especially if you don't have small hands.
I did mine today and it took 4 hours from the start of taking the hose away from the inlet to when the system was refilled and primed. I didn't bother to drain the system...I just put a very big bucket under the front of the truck and disconnected the hose and removed it from the inlet. One of the hose clamps was a bugger. Nissan had put it in a position such that I could not get a ratchet on it and had to use a small wrench making abou 1/16 of a turn at a time creating about a 1/2 hour diversion. Once undone I pulled the hose and let the coolent empty. About 90% of the coolant made it into the bucket, which I thought was pretty good. Removing the inlet proved to be tricky. I could get my small ratchet, extension, and socket down in there, but the bolts must have been driven in by a 2 ton ape with a bad attitude! I nearly broke my ratchet on one of them and had to use a deep well socket and an extension to put on the handle so I could get more leverage. Took me about 1/2 hour to get the bolts out. Removing the bolts resulted in about 20 scratches on my arms and a nice big bruise over two of my knuckles...yep; it was a knuckle buster job!
Once the bolts were out I had to figure out a way to get the inlet off becuase it was stuck on there pretty good with the sealant and such. I finally ended up putting the handle end of a screwdriver against the top of it and them used a hammer to tap the other end of the screwdriver and knock the inlet loose. Then I had to pry the old themostat out with a screwdriver because it was sealed in with sealant and corrosion. When it popped out, the top of the engine drained. Scraped the old sealant off, wiped everything up, and put the new thermo in. Put new sealant on the inlet and put it into place and bolted it on. This was definately the easy part and only took a few minutes. BTW, don't buy the sealant from Nissan for $15!!! You can get the Permatex thermostat housing sealer for about $3 at the auto parts store.
Now, before I hooked the lower hose back up I poured a little coolant into it so it wasn't empty and then reconnected it to the inlet and tightened down the clamps being sure to put them in a better position this time so they could be reached with a ratchet and extension!
Once everything is back together you need to fill the radiator and overflow tank. There is an air relief bolt on the intake manifold that you remove first (can't miss it; has a warning about not removing it when engine is hot). Be careful not to lose the little washer down in a crevice in the engine like I did, thank you! Fishing that out was fun! Anyway, you fill the radiator until coolant (50/50 mix) starts to come out of the air relief hole. Then put the bolt back in and tighten snug; but not too much! Then put the radiator cap back on and start the engine. Let it idle until it's up to operating temperature then rev it a few times to get the coolant flowing. Keep an eye on the temp guage to make sure it doesn't overheat! After running for a bit stop the engine and let it cool for awhile. Then carefully open the radiator cap and check the level. Add coolant if necessary and then run again. Repeat until the coolant level stays. Make sure the overflow tank has a proper level too.
That's about it...LOL!
#195599 - 09/08/03 09:42 PM Re: Thermostat Replacement
drspencer Offline
Doesn't Nissan now offer a thermostat housing gasket instead of the sealant? If so, does anyone have a part #?
Thanks.
#195600 - 29/05/06 05:25 AM Re: Thermostat Replacement
ChrisNYC Offline
Loc: Brooklyn, New Yawk
Sorry to revive such an old topic, but does anyone know if it is necessary to let Permatex thermostat housing sealer to fully cure before running the engine? The full cure time is 24 hours which is far longer than I would like to take replacing the thermostat. The product packaging doesn't have any information pertaining to this.
#195601 - 01/02/07 07:25 AM Re: Thermostat Replacement
ChrisNYC Offline
Just wanted to follow up about the cure time for Permatex thermostat housing sealant. I called them and found that they recommend 8 hours cure time minimum before the engine can be run.
They do have another product called "The Right Stuff",
Link
This can be used for thermostat applications and can be used immediately after application.
Moderator:  johngraves2
