Yesterday at 04:27 PM
#244831 - 03/11/06 10:32 AM Parked X vs Semi...one tough cookie
#244832 - 03/11/06 11:29 AM Re: Parked X vs Semi...one tough cookie
hope no one was hurt...
#244833 - 03/11/06 01:11 PM Re: Parked X vs Semi...one tough cookie
Ouch.. eek
#244834 - 03/11/06 02:52 PM Re: Parked X vs Semi...one tough cookie
Ramness Offline
Loc: Snellville, GA (Atlanta)
Parked with Airbag Deployment? I don't think we are getting the true full story here.
#244835 - 03/11/06 03:16 PM Re: Parked X vs Semi...one tough cookie
Why? Airbags wont deploy when in park??????
M
#244836 - 03/11/06 03:44 PM Re: Parked X vs Semi...one tough cookie
Might no have been "parked"Just stoped. See first pic. My bad
#244837 - 03/11/06 04:27 PM Re: Parked X vs Semi...one tough cookie
Ramness Offline
You need deceleration for airbag deployment. Even if you are just stopped at a light they should not go off.
#244838 - 03/11/06 04:36 PM Re: Parked X vs Semi...one tough cookie
wow
#244839 - 03/11/06 04:54 PM Re: Parked X vs Semi...one tough cookie
xterra3202 Offline
Loc: Georgia
I beg to differ. Airbag systems contain many parts but basically the crash sensors (usually two up front and then two for the newer side and curtain airbags), the SRS control module, and then the actual airbags. The impact upon the sensors is what relays the information to the control module which will decide if the impact is severe enough to fire the airbags. If that Xterra was stopped or even parked and was hit hard enough the system would execute as per its programming not necessarily relying on the deceleration of the Xterra as the impact alone would trigger the system. Same theory as a crash test hitting the concrete wall at 40 mph except the car is moving and the wall is not. The overall goal of the airbag is to reduce forward momentum of the occupants. It would appear in those pictures that the airbags performed as per the design criteria and I would wager probably saved the lives of those in the vehicle (hopefully).
Tim
Thomas Jefferson
#244840 - 03/11/06 06:59 PM Re: Parked X vs Semi...one tough cookie
Not true. In the case of a rear end collision there are acceleration sensors that will deplot the air bag as well.
#244841 - 03/11/06 07:07 PM Re: Parked X vs Semi...one tough cookie
Yep, airbags can/will go off when parked, but the key has to be on. Won't go off if it's parked in the lot.
#244842 - 03/11/06 07:58 PM Re: Parked X vs Semi...one tough cookie
looks like its time for a shrock bumper.. [Laughing]
