Ned has 32-12.50-15 BFG AT/KO's, and under full compression/articulation, he gets rubbing on the rear tires against inner wheel wells. True, he has Revolvers (which give him more articulation, but with about 1-1/2" lift, too). East-coasters have also commented on minor rubbing with the 32's, without the Revolvers.
The biggest problem with 32"+ tires, is it REALLY saps the power, unless you drop to a lower set of R&P's. Ned has had several times where he's had his foot to the floor, and the torque converter just spins -- too much traction coefficient from the tires for the converter to handle without more leverage in the form of axle gearing.
Onward and Forward
or at least Onward
SCCX:
http://www.sccxterra.com/
