I just bought the OEM fog light kit from courtesy nissan. I read the how to on installing the lights but i did not get any bolt holders in my kit. I just had 4 green clips and 4 bolts. Is there another way to put these on or did they mess up?
You should have also received two silver pieces as pictured in the write-up. You only need two of the green pieces. Make sure the silver pieces are not already installed on the foglights. If not, call back to yournissanparts.
There is no silver clips like in the write up. They sent me 4 green clips and 4 bolts. The picture on xterraparts.com shows the 4 green clips and 4 bolts also. fog lights
Maybe the install is different for the '06? If not, you need to call courtesy and ask for the bolt holders because the bolt will not work with the green clips and the bolt will not have anything to bolt to without the silver pieces.
