Same day as the other post but a different event. So after a little mudding and a few big bumps (nothing real jarring but I definately bounced around a bit) and the brakes went all mushy. It feels like there is a huge bubble in the lines. The brakes still work but the pedal is almost on the floor. I also tested the ABS and it still engages, in the mud and soft dirt at least. So what are the possible causes? Did a bubble get sucked in through the bleed line? Did the jarring stir bubbles into the reservoire and subsequently into the cylinder? Can an ABS equiped brake system be bled the same as regular brakes? If I can fix this myself I would rather do that then argue with Nissa about HOW this happened and if it is under warranty
