You should not inflate the tires to the MAX pressure as stated on the sidewall unless you are loading that axle to the maximum weight that pressure is meant to support. If the tire says max load 1500 lbs. @ 35 psi, then that would mean that if you would use 35 psi if you have 3000 lbs. on the axle which is about 1000 lbs. over the normal axle weight if it had a 50/50 weight ratio.
Check your door jamb for the proper inflation pressure of the stock tires, and adjust to suit your taste by a few psi up or down from there.
