I think you will have a hard time finding a brake shop that will turn slotted/drilled rotors. Use a dial caliper or a micrometer to check rotor thickness in a few areas on each and see if you get any great variances in thickness. If you suspect any glazing, you can use some fine grit sandpaper with a orbital sander to knock the glazing off.
