#280579 - 24/05/05 06:35 AM 05 Xterra offset
I have searched and I think it is 30 mm.
Can anyone verify this?
thanks
#280580 - 24/05/05 07:47 AM Re: 05 Xterra offset
I believe you are correct sir. 16 x 7 with a 30mm offset on the S model and SE model is 17 x 7.5 and still with a 30 mm.
#280581 - 24/05/05 08:39 AM Re: 05 Xterra offset
Jake - you have the '04's and prior listed with a 40 mm offset, right?
BTW - The BS was 5.25" on the 04's and prior, what is it for the 05's?
#280582 - 24/05/05 11:55 AM Re: 05 Xterra offset
i think the BS is 4.5, not sure.
also is there a difference if i was to get a 17X8 vs. 17X7.5?
#280583 - 24/05/05 12:16 PM Re: 05 Xterra offset
'bout a half inch.
(7.5" to 8" rim...)
#280584 - 24/05/05 02:21 PM Re: 05 Xterra offset
xcanuk Offline
Loc: Mtl. Que. Canada
Just check the last few pages of your owners manual to be sure, it should be listed there with the rest of the specs.
member of http://www.soxc.org
#280585 - 25/05/05 08:31 AM Re: 05 Xterra offset
Actually I show the 03 and 04 models to have a 30 mm offset also. Not a 40.
#280586 - 25/05/05 09:02 AM Re: 05 Xterra offset
That's odd, I could have sworn the pre-'05's had a 40 mm offset.
[Freak]
#280587 - 25/05/05 09:16 AM Re: 05 Xterra offset
Just checked...its 40 mm offset.
Jake - Change your data base for the pre-'05's....its a 40 mm offset, not a 30 mm as you have listed.
Second - If the '05's offset changed to 30 mm, the other's offset's may have been accidntally switched too, or, the '05's might be wrong as well, if they are the same as pre-'o5's, they too will be 40 mm offset.
Geez, now someone has to go and measure the offset on a '05.
(The offset was already measured as 40 mm on pre-'05's)
#280588 - 16/06/05 08:16 PM Re: 05 Xterra offset
just curious to know if there will be any updates for 05 rims. been on and off the tire rack website and still no listings for rims for the 05.
#280589 - 17/06/05 05:36 AM Re: 05 Xterra offset
The manual lists 40 mm offset, not 30 mm.
